enable sip on IAD
Joli Martinez
I have an old 2400 series IAD.  I am configuring this for SIP traffic.  Is there anything special I need to do to enable SIP on it.  I have configured the dial-peer below and it is not sending the traffic to session target.  I see the call comes in and it matches this dial-peer correctly, but from there the call dies and never goes out.  What am I missing?
dial-peer voice 103 voip
 description 10 Digit Dialing
 translation-profile outgoing E164
 destination-pattern [2-9].........
 session protocol sipv2
 session target ipv4:10.21.10.10
 session transport udp
 dtmf-relay rtp-nte
 codec g711ulaw
 fax-relay ecm disable
 fax-relay sg3-to-g3
 ip qos dscp cs5 media
 ip qos dscp cs4 signaling
 no vad
INVITE sip:3334445555@10.41.100.5 SIP/2.0
Via: SIP/2.0/UDP 10.41.100.2:5080;rport;branch=z9hG4bKetaj2eS80yNQa
Max-Forwards: 69
From: "LCS" <sip:FreeSWITCH@10.41.100.5>;tag=eKvvvN70gKveQ
To: <sip:3334445555@10.41.100.5>
Call-ID: 231b0a87-e56b-1238-0aa6-005056873da3
CSeq: 17807162 INVITE
Contact: <sip:gw+17530ce2-2aba-4f3e-8a16-dc3295c03661@10.41.100.2:5080;transport=udp;gw=17530ce2-2aba-4f3e-8a16-dc3295c03661>
User-Agent: FreeSWITCH
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, INFO, UPDATE, REGISTER, REFER, NOTIFY
Supported: timer, path, replaces
Allow-Events: talk, hold, conference, refer
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 293
X-FS-Support: update_display,send_info
Remote-Party-ID: "LCS" <sip:7778889999@10.41.100.5>;party=calling;screen=yes;privacy=off
v=0
o=FreeSWITCH 1584696828 1584696829 IN IP4 10.41.100.2
s=FreeSWITCH
c=IN IP4 10.41.100.2
t=0 0
m=audio 24384 RTP/AVP 9 0 8 101
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
*Mar  8 21:28:55.148: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Mar  8 21:28:55.148: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x65BA5380) with key=[31] to table
*Mar  8 21:28:55.148: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.41.100.2,Port 5080, Transport 1, SentBy Port 5080
*Mar  8 21:28:55.148: //-1/53D840FF8066/SIP/State/sipSPIChangeState: 0x65BA5380 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
*Mar  8 21:28:55.148: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 10.41.100.2,Port 5080, Transport 1, SentBy Port 5060
*Mar  8 21:28:55.148: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Mar  8 21:28:55.152: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_lock: Increment msg (0x657AF4E8) counter,
                current msg->refCount = 2
*Mar  8 21:28:55.152: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free: Freeing NULL pointer!
*Mar  8 21:28:55.152: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAssignCcbLastRequest: Current ccb(0x65BA5380)->last_request = 0x657AF4E8, refCount = 2
*Mar  8 21:28:55.152: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckIpip: VOIP dialpeer (peer=0x640D45FC) found for sip_user: 3334445555
*Mar  8 21:28:55.152: //-1/53D840FF8066/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: LCS, current remote number: 7778889999
*Mar  8 21:28:55.152: //-1/53D840FF8066/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
*Mar  8 21:28:55.152: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
*Mar  8 21:28:55.152: //-1/53D840FF8066/SIP/Info/sipSPIUaddCcbToUASReqTable: ****Adding to UAS Request table.
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x65BA5380 key=231b0a87-e56b-1238-0aa6-005056873da33334445555
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on carrier id
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on Incoming called number: 3334445555
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIMatchSrcIpGroup: Match not found on destination pattern: 7778889999
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/ccsipUpdateIncomingCallParams: ccCallInfo: Calling name LCS, number 7778889999, Calling oct3 0x00, oct_3a 0x81, Called number 3334445555
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIGetCallConfig: Peer tag 103 matched for incoming call
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIGetCallConfig: Precondition tag absent in Require/Supported header
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 711
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Media/sipSPICopyPeerDataToCCB: Firewall traversal is not enabled
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
*Mar  8 21:28:55.156: //-1/53D840FF8066/SIP/Info/sipSPIGetCallConfig: Media forking disabled
*Mar  8 21:28:55.160: //-1/53D840FF8066/SIP/Info/sipSPIContinueNewMsgInvite: Calling name LCS, number 7778889999, Calling oct3 0x00, oct_3a 0x81, ext_priv 0x00, Called number 3334445555, oct3 0x00
*Mar  8 21:28:55.160: //-1/53D840FF8066/SIP/Info/sipSPIContinueNewMsgInvite: Carrier id code , prev_cid NONE, next_cid NONE, prev_tgrp NONE, next_tgrp NONE
*Mar  8 21:28:55.160: //-1/53D840FF8066/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
*Mar  8 21:28:55.160: //19/53D840FF8066/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
*Mar  8 21:28:55.160: //19/53D840FF8066/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container
*Mar  8 21:28:55.160: //19/53D840FF8066/SIP/Info/sipSPIProcessReplacesHeader: No replaces hdr found
*Mar  8 21:28:55.160: //19/53D840FF8066/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
SIP: (19) Attribute mid, level 1 instance 1 not found.
*Mar  8 21:28:55.160: //19/53D840FF8066/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.41.100.5
*Mar  8 21:28:55.160: //19/53D840FF8066/SIP/Media/sipSPISelectCodecVersion: g722-64  flavor of G722 codec will be used
*Mar  8 21:28:55.160: //19/53D840FF8066/SIP/Info/sipSPIDoAudioNegotiation: Codec (g722-64) Negotiation Successful on Static Payload for m-line 1
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
*Mar  8 21:28:55.164: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g722-64 ptime :20, codecbytes: 160
*Mar  8 21:28:55.164: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g722-64 codecbytes :160, ptime: 20
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g722-64
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved.
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
*Mar  8 21:28:55.164: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
payload_type=9, codec_bytes=160, codec=g722-64, dtmf_relay=rtp-nte
stream_type=voice+dtmf (1), dest_ip_address=10.41.100.2, dest_port=24384
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Media/sipSPIUpdCallWithSdpInfo:
Preferred Codec        : g711ulaw, bytes :160
Preferred  DTMF relay  : rtp-nte
Preferred NTE payload  : 101
Early Media            : No
Delayed Media          : No
Bridge Done            : No
New Media              : No
DSP DNLD Reqd          : No
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 10.41.100.5
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPI_ipip_report_media_to_peer:
 callId 19 peer 0 flags 0x201 state STATE_IDLE
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo:
CallID 19, sdp 0x65EFE538 channels 0x65BA6640
*Mar  8 21:28:55.164: //19/53D840FF8066/SIP/Info/copy_channels:
 callId 19 size 0 ptr 0x657B2670)
Hndl ptype 9 mline 1
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Media/sipSPISelectCodecVersion: g722-64  flavor of G722 codec will be used
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g722-64
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/codec_found:
Codec to be matched: 37
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 37
*Mar  8 21:28:55.168: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g722-64 codecbytes :160, ptime: 20
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation done: stream->negotiated_ptime=20,stream->negotiated_codec_bytes=160, coverted ptime=20 stream->mline_index=1, media_ndx=1
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo:
failed to update call entry
Adding codec 37 ptype 9 time 20, bytes 160  as channel 0 mline 1 ss 0 10.41.100.2:24384
Hndl ptype 0 mline 1
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711ulaw
Codec to be matched: 5
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 5
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Media negotiation NOT done, get ptime from sdp: ptime=20, media_ndx=1
*Mar  8 21:28:55.168: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
Adding codec 5 ptype 0 time 20, bytes 160  as channel 1 mline 1 ss 0 10.41.100.2:24384
Hndl ptype 8 mline 1
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Selecting codec g711alaw
Codec to be matched: 6
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: ADD AUDIO CODEC 6
*Mar  8 21:28:55.168: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711alaw ptime :20, codecbytes: 160
Adding codec 6 ptype 8 time 20, bytes 160  as channel 2 mline 1 ss 0 10.41.100.2:24384
Hndl ptype 101 mline 1
*Mar  8 21:28:55.168: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: setting ipip_caps DTMF to RFC2833: callid = 19, dtmf = 6
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 37
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 5
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = 6
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPI_ipip_copy_sdp_to_channelInfo: Copy sdp to channel- AFTER CODEC FILTERING: ccb->pld.ipip_caps.codecInfo[channel_ndx].codec = -1
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPI_ipip_report_media_to_peer:
 callId 19 flags 0x300 state STATE_IDLE
Report initial call media
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPI_ipip_report_media_to_peer: ccb->flags 0xC, ccb->pld.flags_ipip 0x201
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/copy_channels:
 callId 19 size 696 ptr 0x65EE0014)
CCSIP: Unable to report channel ind
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/ccsip_update_srtp_caps:  5054: Posting Remote SRTP caps to other callleg.
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPI_ipip_report_media_to_peer: do cc_api_caps_ind()
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Media/sipSPIUpdCallWithSdpInfo:
 Stream type            : voice+dtmf
 Media line             : 1
 State                  : STREAM_ADDING (2)
 Stream address type    : 1
 Callid                 : -1
 Negotiated Codec       : g722-64, bytes :160
 Nego. Codec payload    : 9 (tx), 9 (rx)
 Negotiated DTMF relay  : rtp-nte
 Negotiated NTE payload : 101 (tx), 101 (rx)
 Negotiated CN payload  : 0
 Media Srce Addr/Port   : [10.41.100.5]:0
 Media Dest Addr/Port   : [10.41.100.2]:24384
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPIHandleInviteMedia:
Preferred  DTMF relay 1 : 6
Preferred  DTMF relay 2 : 0
Negotiated DTMF relay   : 6
Preferred and Negotiated NTE payloads: 101 101
Preferred and Negotiated NSE payloads: 100 0
Preferred and Negotiated Modem Relay: 0 0
Preferred and Negotiated Modem Relay GwXid: 1 0
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: Entry
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
*Mar  8 21:28:55.172: //19/53D840FF8066/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
*Mar  8 21:28:55.176: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16700 for stream 1
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPIUpdateSrcSdpFixedPart: Reserving rtp port for stream 1, src_port=16700
*Mar  8 21:28:55.176: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 16700
 SIP update src sdp, negoitated codec 37, payload type 9
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPIAddBillingInfoToCcb: sipCallId for billing records = 231b0a87-e56b-1238-0aa6-005056873da3
*Mar  8 21:28:55.176: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentCPA: No CPA found in inbound container
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPIProcessCPA: No x-cisco-cpa content found
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPI_ipip_store_channel_info: Store channelInfo in CallInfo
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPI_ipip_store_channel_info: dtmf negotiation done, storing negotiated dtmf = 6,
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/sipSPIShrlCall: Check peer: 103 for Shared-Line call, callid: 19
*Mar  8 21:28:55.176: //19/53D840FF8066/SIP/Info/ccsip_set_bearer_capability:
   Bearer Capability: Speech (0x00)
*Mar  8 21:28:55.176: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
*Mar  8 21:28:55.176: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
*Mar  8 21:28:55.176: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
*Mar  8 21:28:55.180: //19/53D840FF8066/SIP/Info/sipSPIContinueNewMsgInvite: ccsip_api_call_setup_ind returned: SIP_SUCCESS
*Mar  8 21:28:55.180: //19/53D840FF8066/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 13 to table
*Mar  8 21:28:55.180: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_create: created msg=0x65E5A6A0 with refCount = 1
*Mar  8 21:28:55.180: //19/53D840FF8066/SIP/Transport/sipSPITransportSendMessage: msg=0x65E5A6A0, addr=10.41.100.2, port=5080, sentBy_port=5080, is_req=0, transport=1, switch=0, callBack=0x00000000
*Mar  8 21:28:55.180: //19/53D840FF8066/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  8 21:28:55.180: //19/53D840FF8066/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  8 21:28:55.180: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x65E5A6A0, addr=10.41.100.2, port=5080, connId=0 for UDP
*Mar  8 21:28:55.180: //19/53D840FF8066/SIP/State/sipSPIChangeState: 0x65BA5380 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_RECD_INVITE, SUBSTATE_NONE)
*Mar  8 21:28:55.180: //19/53D840FF8066/SIP/Info/sipSPIProcessContactInfo: Previous Hop 10.41.100.2:5080
*Mar  8 21:28:55.184: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_PROCEEDING
*Mar  8 21:28:55.188: //19/53D840FF8066/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
*Mar  8 21:28:55.188: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
*Mar  8 21:28:55.188: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 3
*Mar  8 21:28:55.188: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
*Mar  8 21:28:55.188: //19/53D840FF8066/SIP/Info/act_recdinvite_disconnect: Performing disconnect
*Mar  8 21:28:55.192: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_create: created msg=0x64DC9174 with refCount = 1
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/Info/sipSPIUaddCcbToUASRespTable: ****Adding to UAS Response table.
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x65BA5380 key=231b0a87-e56b-1238-0aa6-005056873da328A88EC8-DDC
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/Info/sipSPISendInviteResponse: Associated container=0x65D9D688 to Invite Response 404
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/Transport/sipSPITransportSendMessage: msg=0x64DC9174, addr=10.41.100.2, port=5080, sentBy_port=5080, is_req=0, transport=1, switch=0, callBack=0x61B0A9D4
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
*Mar  8 21:28:55.192: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x64DC9174, addr=10.41.100.2, port=5080, connId=0 for UDP
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/Info/sentErrResDisconnecting: Sent an 3456XX Error Response
*Mar  8 21:28:55.192: //19/53D840FF8066/SIP/State/sipSPIChangeState: 0x65BA5380 : State change from (STATE_RECD_INVITE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
*Mar  8 21:28:55.196: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
0 Replies 0
