Enable SIP OPTIONS 200OK on CUBE.
Ritesh Desai
Hi folks,
I have IPT setup with CUBE configured. Customer is having Genesys environment which will sending calls to Cisco extensions. SIP Trunk is terminated on CUBE. At Customer side, SIP service shows out of service. To enable SIP service, customer suggested to send SIP OPTIONS 200OK messages and then inbound calls can be sent. Traces to be send to customer.
On CUBE, by #show sip-ua service command shows me SIP service is UP.
CUBE - ISR 4431 Gen3 router. IOS version: 3.16
Please suggest how shall I achieve this.
Thanks & regards,
Ritesh Desai.
*** Please rate helpful post. Please mark as answer if it solves your problem/query.
regards, Ritesh Desai
6 Replies 6
Rajan
Hi Ritesh,
Please follow the below link:
http://www.cisco.com/c/en/us/td/docs/ios/voice/cube/configuration/guide/vb_book/vb_book/vb_9321.html#wp1452667
Rajan
Pls rate all useful posts
Hi @rajan,
I have configured as per the guide but looks like ports not telneting.
thanks & regards,
Ritesh Desai.
You may need to check the firewall if any.
Hi Rajan,
I got a customer saying, ports are opened only for Virtual IP. Can you suggest how shall I proceed further. As this is my 1st deployment.
thanks & regards,
Ritesh Desai.
Hi Rajan,
Im facing difficulty. I have a SIP dial-peer configured and pointing to remote SIP Trunk SBC. I have set command #voice-class sip options-keepalive on SIP Dial-peer. I have 2 SIP trunks 1 trunk on each SBC. I have configured on both SBC's.
By #sh dial-peer voice summary, both SIP TRUNK dial-peer shows ACTIVE. So, I initiate extended ping from SBC and see 100% packet loss. Post then I see #show dial-peer voice summary. SBC Dial-peer goes busyout.
Why so?
Doing shut / no shut on dial peer donot work. I tried with reload of router and dial peer showed up and the same thing as above.
I referred docs on google but no luck. Can you suggest some hints and guidance.
Appreciated in advance.
thanks & regards,
Ritesh Desai.
Hi folks,
Ny luck folks...
SIP Trunk between my SBC and Client SBC shows down. any other possibilities should I look at...?
please suggest.
thanks & regards,
Ritesh Desai
