09-19-2011
12:56 PM
- last edited on
03-25-2019
08:09 PM
by
ciscomoderator
Is there a way to enable Web access on ip phones in Communications Manager Express?
CME Version- 8.5
Phone Model- 7965
Phone Load- SCCP45.9-1SR1S
This doesnot seem to be configurable on the phone and I have not located a way to do this in the GUI.
Solved! Go to Solution.
09-19-2011 02:17 PM
Hi Chris
It's something like this:
You can enable this for all phones like as follows (this will just insert the webAccess parameter into the vendor specific section of the XML config file the phones load as they boot - the webAccess bit may be case sensitive).
Telephony-service
Service phone webAccess 1
Create cnf-files
Then restart your phones...
May well be webAccess 0, can't quite remember which way round it was..
Aaron
Please rate helpful posts...
09-19-2011 02:17 PM
Hi Chris
Telephony-service
Create cnf-files
Aaron
08-19-2019 07:30 AM
Hello Aroon,
How enable web GUI access with sip phones on CME ? ... I cant do this
09-20-2011 09:23 AM
That was it.
webAccess 0 did it.
Thanks!
