encryption in CISCO IP phones (SCCP)
Thiago Gandara
Hi voice team,
I've been researching about encryption in CISCO IP phones (SCCP) I'm a little confused because the manual does not explain in a clear way, could someone explain to me in a simple way how to set up encryption on phones models: 7941, 7942, 7911, 7937 , 7921 and CIPC ?
Thiago.
Chris Deren
Thiago,
Because it is not that simple, have you read the CUCM security guide:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/9_1_1/secugd/CUCM_BK_C0395F44_00_cucm-security-guide-91.html
Probably a very good start
HTH,
Chris
Chris Deren
Thiago,
HTH,
Chris
I have i doubt, to set up encryption on phones I'll need a USB Token? At least that's what I understood reading the document.
how to do this without using encryption USB Token?
Thiago
You are correct, you need the tokens to create the certificates, no way around it. Though they are pretty cheap.
Chris
Alrigth, thank you very much.
