end user permission
kp-tkr2014
How to give permission to the  end user only for a certain number or numbers  to handle voice mail forwarding  /call forwarding
No, that's exactly what I explained in my previous reply. If they have access to the DN page, they have access to ALL DNs.
java
if this helps, please rate
Jaime Valencia
I'll assume you mean in CUCM as you don't mention.
Not possible, the most granular you can be is whether they have access to a certain page or not, but ANYTHING within that page can be modified (ie devices or DNs). No way to configure access to only a subset of elements, or a subset of fields within an element.
java
Is it possible to give permission only one directory number
java
