Enterprise CP-BEKEM= to Webex Calling
I have CP-BEKEM= key expansion modules connected on CP-8851 phones registered in CUCM. Since we are in the process of migrating to Webex Calling I would like to know if those modules can be connected to MPP 8851 phone so we can use them in Webex Calling.
CP-BEKEM= are listed on Supported devices for Webex Calling document. But Add Buttons to Your Phone (8800 Series) document explains both. its an outdated document.
I will suggest to do a test before replacing the CP-BEKEM
https://help.webex.com/en-us/article/oyhaly/Add-Buttons-to-Your-Phone-(8800-Series)
Kindly note that CP-BEKEM= are EOL announced part number.
Response Signature
TechLvr
@Michalis Michael Yes, you can. Please refer to the link below.
https://help.webex.com/en-us/article/n9r1aac/Configure-and-manage-Webex-Calling-devices#Cisco_Reference.dita_f319835c-5a42-44d4-9379-016a5e11a452
"When you connect accessories (Headsets/KEMs) to an MPP device, they appear as an inventory item under the Devices tab in Control Hub." You can then configure the accessories, KEM in your case, from the Control Hub.
Thank you for your response.
The Table 2 from the link says that BEKEM is supported but does not clarify if both enterprise SKU (CP-BEKEM=) and MPP SKU (CP-BEKEM-3PCC=) are supported.
Ah Sorry. CP-BEKEM= is not in the list of supported SKUs for MPP phones.
You can find this info in the link below.
https://help.webex.com/en-us/article/qkwt4j/Supported-devices-for-Webex-Calling
Response Signature
