02-05-2009 07:13 AM - edited 03-15-2019 04:01 PM
Hi to all,
i have an ERISCSSON MD110 PBX connecte via an isdn BRI interface to a cisco 2811.I can see the bri interface up,up ma i can't see q921 signaling passing through the interface and i can't place calls.
PBX has QSIG GFP(the PBX manager told me) signaling type and i configured basic-qsig under BRI.
any idea?
thx....
02-05-2009 08:25 AM
Are you made the crossed cable and config as per:
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_configuration_example09186a008010ef6c.shtml
02-05-2009 08:44 AM
No i'm using a crossover(3-->4,4-->3,5-->6,6-->5) i tried yestarday also with the combination shown in your link but it did not work.maybe some problem with qsig GFP
02-05-2009 08:47 AM
No it must be done as per link, configure properly and it will work.
02-05-2009 08:48 AM
can you explai better?
02-05-2009 08:54 AM
Alessandro, what should I explain, it's all in the document. Currently you have the wrong cable and not posted your config.
02-05-2009 09:11 AM
interface BRI0/3/1
no ip address
isdn switch-type basic-qsig
isdn overlap-receiving T302 3000
isdn protocol-emulate network
isdn layer1-emulate network
isdn incoming-voice voice
isdn T310 120000
isdn static-tei 0
isdn skipsend-idverify
and also i find this combination(see attached.
02-05-2009 09:41 AM
Seems fine, you don't need
isdn T310 120000
The diagram you posted is pin numbers and functions, not the cross-over cable wiring.
