02-07-2007 11:31 AM - edited 03-14-2019 07:54 PM
When I am trying to add users in call manager I am getting the following error "The phone administrator is currently not allowed to add or delete users" I have verified the access rights for the user and they appear to be correct.
02-07-2007 11:47 AM
Is this active directory integrated or is this DC directory. Need this information to solve the problem.
02-07-2007 11:55 AM
sorry, this is call manager 3.3 with DC directory
02-07-2007 12:07 PM
You might try and run adminutility to see if all of your passwords are in synch. Run this in non business hours because it restarts services.
Please rate helpfull posts
02-07-2007 01:10 PM
Try this before you run the utility.
Step 1. select start > Run and type regedit
Step 2. Go to the following key:
HKEY_LOCAL_MACHINE>SOFTWARE> Cisco Systems, INC. > Directory Configuration
Step 3. You should see a key named DIRACCESS. By default, the value of this key is set to False. Change the value of this key to true.
Step 4. Restart the IIS ADmin Service.
02-08-2007 07:51 AM
I tried changing the registry and this did allow me to bring up the page to enter the user information. However when I press insert then I get an error.
02-08-2007 12:33 PM
Did you restart IIS?
02-08-2007 12:38 PM
Yes
