Error Call Manager 7.1.3 CLI
Hi, all.. I have a problem here,
My Publisher suddenly stoped some administratve services lice Cisco Tomcat, AMC, Phone registered Monitor, etc, so now the phones are registered but I cannot see anything (no status).
I try to enter de CLI to restar manually some services and I got this error every 2-3 minutes.
Command Line Interface is starting up, please wait ...
/usr/local/platform/bin/cliscript.sh: line 137: 28857 Killed                  /bin/nice -n 10 java -DConsoleRows=$ROWS -DConsoleColumns=$COLS sdMain name=$name priv=$priv $master
Copyright Cisco Systems 2006-2008
What do you recommend at this point?
Look at the administrative services.
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco AMC Service[STOPPED]  Component is not running
Cisco AXL Web Service[STOPPED]  Commanded Out of Service
Cisco Audit Event Service[STARTED]
Cisco Bulk Provisioning Service[STARTED]
Cisco CAR Scheduler[STOPPED]  Component is not running
Cisco CAR Web Service[STOPPED]  Commanded Out of Service
Cisco CDP[STARTED]
Cisco CDP Agent[STARTED]
Cisco CDR Agent[STARTED]
Cisco CDR Repository Manager[STOPPED]  Component is not running
Cisco CTIManager[STARTED]
Cisco CallManager[STARTED]
Cisco CallManager Admin[STOPPED]  Commanded Out of Service
Cisco CallManager Attendant Console Server[STOPPED]  Component is not running
Cisco CallManager Cisco IP Phone Services[STOPPED]  Commanded Out of Service
Cisco CallManager Personal Directory[STOPPED]  Commanded Out of Service
Cisco CallManager Serviceability[STOPPED]  Commanded Out of Service
Cisco CallManager Serviceability RTMT[STOPPED]  Commanded Out of Service
Cisco Certificate Expiry Monitor[STARTED]
Cisco DRF Local[STARTED]
Cisco DRF Master[STOPPED]  Component is not running
Cisco Database Layer Monitor[STARTED]
Cisco Dialed Number Analyzer[STOPPED]  Commanded Out of Service
Cisco Extended Functions[STARTED]
Cisco Extension Mobility[STOPPED]  Commanded Out of Service
Cisco Extension Mobility Application[STOPPED]  Commanded Out of Service
Cisco IP Manager Assistant[STOPPED]  Commanded Out of Service
Cisco License Manager[STARTED]
Cisco Log Partition Monitoring Tool[STARTED]
Cisco RIS Data Collector[STOPPED]  Component is not running
Cisco RTMT Reporter Servlet[STOPPED]  Commanded Out of Service
Cisco SOAP - CDRonDemand Service[STARTED]
Cisco Serviceability Reporter[STARTED]
Cisco Syslog Agent[STARTED]
Cisco Tftp[STARTED]
Cisco Tomcat[STARTING]
Cisco Tomcat Stats Servlet[STOPPED]  Commanded Out of Service
Cisco Trace Collection Service[STARTED]
Cisco Trace Collection Servlet[STOPPED]  Commanded Out of Service
Cisco UXL Web Service[STOPPED]  Commanded Out of Service
Host Resources Agent[STARTED]
MIB2 Agent[STARTED]
Native Agent Adapter[STARTED]
SNMP Master Agent[STARTED]
SOAP -Log Collection APIs[STARTED]
SOAP -Performance Monitoring APIs[STARTED]
SOAP -Real-Time Service APIs[STARTED]
System Application Agent[STARTED]
Cisco CTL Provider[STOPPED]  Service Not Activated
Cisco CallManager SNMP Service[STOPPED]  Service Not Activated
Cisco Certificate Authority Proxy Function[STOPPED]  Service Not Activated
Cisco DHCP Monitor Service[STOPPED]  Service Not Activated
Cisco DirSync[STOPPED]  Service Not Activated
Cisco IP Voice Media Streaming App[STOPPED]  Service Not Activated
Cisco Messaging Interface[STOPPED]  Service Not Activated
Cisco TAPS Service[STOPPED]  Service Not Activated
Cisco Unified Mobile Voice Access Service[STOPPED]  Service Not Activated
Cisco WebDialer Web Service[STOPPED]  Service Not Activated
Primary Node =true
Could you please give me an advice?
Aaron Harrison
Maybe take a look at your memory stats using RTMT or the server CLI.
Typically you see problems with Tomcat as a result of memory starvation - and usually this is down to a memory leak in some process or other on the server. It usually requires an upgrade to resolve.
A reboot will cure it temporarily if that's the case - if you haven't rebooted this server for a long time it will probably get you a similar amount of time to the current uptime.
Aaron Harrison
Principal Engineer at Logicalis UK
Please rate helpful posts...
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron Harrison
Thanks, I roboted the server and everything os all right!
