IP Telephony and Phones
Labels
I have a 2921 running CME IOS 15.4. I am trying to TFTP to 2921 and it fails. I can TFTP to a 2960.I am using 3com and Solarwinds neither will work with 2921 both work 2960.Anyone have any ideas? I am lost on this. FTP fails as well
miket by Level 5
  • 169 Views
  • 1 replies
I know that this was not possible several versions ago but have not checked since then so I'm hoping they've come up with some method in the last few years.  I need the user to show up as an end user through LDAP integration but I do not want them to...
 Hi Guys,I've been stuck with this for the last 2 days, and I thought to try and use Cisco's forum, I setup my home DC, and started having problems once I moved a Cisco 5505 behind a Cisco 1841 router, I was no longer able to ping some devices, then ...
Hi everyone. I need an CUCM ver 9.12 and gateway SRST with IOS :c2900-universalk9-mz.SPA.154-1.T1.bin". but the IP phones model 8831 (cmterm-8831-sip.9-3-3-5.cop.sgn) not registering when the router SRST is active. The other SIP phones 69XX if are re...
jagifoto1 by Level 1
  • 2519 Views
  • 6 replies
  Hi all can someone help me out with digit manipulation i have 5 extensions numbers  that al start with 7XXXX ( al different numbers )What i would like to realize is that when one of those extensions make calls out the number presentation wil change...
monasir by Level 1
  • 189 Views
  • 1 replies
Hi I am new to voip. My service provider reported that traffic to a specific number from my CUCM is suspicious and asked to validate.What is the way to identify the caller (i have the called number provided by my provider) ? CUCM MCS 7835I3 & version...
Hello,I have 1 DR site and I have configured to access them from HO by pressing 8 access code  and the 4 digit extension, everything is working fine. I have a problem for corporate directories which on phone displays users full number 12345678 when a...
Hi everyone,I have  question  i have cucm 8.5 and integrated with  cisco unity connection 9 and i am attempting to create an auto-attendant  where a caller will dial a DID and be greeted with a message and then given the option to press 0 for operati...
A laban by Level 1
  • 1648 Views
  • 11 replies
