Showing results forĀ
Search instead forĀ
Did you mean:Ā
%Error: Cannot reach license daemon (Specified UDI not found or Daemon is down) - CUE
shiblyibrahim
Level 3
Level 3
Hey,
Hope someone can help me with this.
but show license udi does give me the SN and UDI
se-192-168-154-251# show license udi
Device# PID SN UDI
*0 AIM-CUE FOCXXXXXXXXXX AIM-CUE:FOCXXXXXXXXXX
Cant check licenses if i do show license i get the below
or if i try to reinstall license i get the below
se-192-168-154-251# $@192.168.154.3/FOC11320900_20151130160634005.lic
Installing...Feature:VMIVR-VM-MBX...Failed:Specified UDI not found
Installing...Feature:VMIVR-PORT...Failed:Specified UDI not found
0/2 licenses were successfully installed
0/2 licenses were existing licenses
2/2 licenses were failed to install
Any help will be appreciated.
Please rate the post Shibly Ibrahim
Nadeem Ahmed
Is the license file having correct ? with correct UDI number. Did you tried to open and verify the same.
Br,
Nadeem
Br, Nadeem Please rate all useful post.
Hi Nadeem,
Yes its correct
Hi Nadeem,
Its resolved.
If anyone experiences in the future please follow the below
Required a clean install via the boot-helper and this fixed the issue. Backup CUE before doing anything, if you experience issues via the GUI then do it via the commandline under the offline mode.
shiblyibrahim
Level 3
Level 3
Hi Nadeem,
Its resolved.
