error in cme
kailash_sharma
I have a CME installed in ISR . frequently i am getting this alert in our monitoring tool :  "  Interface VoiceEncapPeer20067 is Down for xxxxxxxx
and it's management IP is 0.0.0.0
Can anyone plese tell me what is the cause,reason for this ... is it service affecting ...
K.S.
6 Replies 6
Gregory Garrian
Can you post the results of:  "show dial-peer voice 20067" ?
nikshah
do a show dial-peer voice 20067
also do a show dial-peer voice summ and see if the dial-peer is down
Pls find the dial-peer status
#show dial-peer voice 20067
VoiceEncapPeer20067
        peer type = voice, system default peer = FALSE, information type = voic
        description = `',
        tag = 20067, destination-pattern = `9999$',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 20067, Admin state is up, Operation state is up,
        incoming called-number = `', connections/maximum = 0/unlimited,
        DTMF Relay = disabled,
        URI classes:
            Destination =
        huntstop = enabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        mailbox selection policy: none
        type = pots, prefix = `',
        forward-digits 0
        session-target = `', voice-port = `50/0/115',
        direct-inward-dial = disabled,
        digit_strip = enabled,
        register E.164 number with H323 GK and/or SIP Registrar = TRUE
        fax rate = system,   payload size =  20 bytes
        supported-language = ''
        preemption level = `routine'
        bandwidth:
            maximum = 64 KBits/sec, minimum = 64 KBits/sec
        voice class called-number:
            inbound = `', outbound = `'
        dial tone generation after remote onhook = enabled
        mobility=0, snr=, snr_noan=, snr_delay=0, snr_timeout=0
        snr calling-number local=disabled, snr ring-stop=disabled, snr answer-t
o-soon timer=0
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 0, Charged Units = 0,
        Successful Calls = 0, Failed Calls = 0, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "",
        Last Disconnect Text is "",
        Last Setup Time = 0.
        Last Disconnect Time = 0.
VoiceEncapPeer20067
        description = `',
        allow watch = FALSE
        URI classes:
            Destination =
        huntstop = enabled,
        dnis-map =
        permission :both
        forward-digits 0
        bandwidth:
o-soon timer=0
HI As i have posted the Dial-peer above . please note i do not have any such dialpeer created in the CME (  dial-peer voice 20067) then why i am getting this error .
Thanks a Ton
K.S.
HI
Are you getting this message in Cisco Works.
We have a bug which is as follows
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCdx64809
Ronak patel
Rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak
We Have HP NNM monitoring tool where i got this error.
K.S.
