Showing results forĀ
Search instead forĀ
Did you mean:Ā
Error message if all the trunks are busy..
SAIFUDEEN C .K
Hi All,
I would like to know the error message will user get if all the trunks are busy.
For example,I have one T1 PRI and all the 23 channels are used up.If a user tries  to call pstn line,that means 24th call,what will be the error message that user will receive.
thanks alot in advance
Saif
Nishant Savalia
Level 4
Level 4
I think the message will be "No Channel available" in ideal condition but you may also get "User Busy" error code too.
Regards, Nishant Savalia
