Error message meaning "Failure reason=error:CTIERR_REDIRECT_CALL_PROTOCOL_ERROR=0x8ccc0033"
sukhdipsingh1
Hi All,
I am currently using UCCX 10.5/CM 10.5 and I have a Germany number which is pointing to the Norway service desk number and onto UCCX script, in Script for OOH we have diverted the call to a mobile number - now when I am dialing German number my call is getting onto script and OOH message is getting played but call is not routing to mobile number, call is getting disconnected, however when I dial Norway number my call is getting through to OOH message first and then onto mobile number.
Mobile number is of Norway, now when I have collected the logs I am getting the error message :Failure reason=error:CTIERR_REDIRECT_CALL_PROTOCOL_ERROR=0x8ccc0033"
Please can someone help me in knowing what this error message relates too and what configuration is missing on the server. Thanks
Sukhdip Singh
5 Replies 5
ilyas.safarov
Hi ,
Did you resolve this issue?
I've faced with the same
Thank you
Did either of you find a resolution to this issue?
Thank you.
@Casey Dockry  are you using Standard Local Route Groups in your design?
Yes
It will make sense if you will check whether the device pool of CTI ports is configured with Route Groups to be able to make outbound calls.
In my case ,this was an issue.
