Error Parsing Kickstart Config : CUCM 9.1.2 Installation on VM
Fikri FIRAT
Level 5
Level 5
Hi all,
After getting done with the configuration, I got the following error, rebooting didn't help, either, any ideas?
Hi Fikri.
Did you create a brand new virtual disk or you just used an old one?
Anyway try to recreate the virtual disk and try again.
If you can use the OVA template downlodable from cco
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
We have increased the disk capacity and resolved the error, the installation went fine, but I did get another error, any ideas on this one?
Fikri
Hi.
Check the virtual machine network settings and also , try to check if you are using a corrupted ISO.
Carlo
well, I get the problem when I choose autonegotiate and the server cannot autonegotiate. So I try to not choose autonegotiate and this problem not occured at install.
Please check your ethernet already assign at VM
