09-19-2013 01:35 AM - last edited on 03-25-2019 08:25 PM by ciscomoderator
Hi all,
After getting done with the configuration, I got the following error, rebooting didn't help, either, any ideas?
09-19-2013 01:59 AM
Hi Fikri.
Did you create a brand new virtual disk or you just used an old one?
Anyway try to recreate the virtual disk and try again.
If you can use the OVA template downlodable from cco
Carlo
Please rate all helpful posts
"The more you help the more you learn"
09-19-2013 05:40 AM
Hi Carlo,
We have increased the disk capacity and resolved the error, the installation went fine, but I did get another error, any ideas on this one?
Fikri
09-19-2013 07:14 AM
Hi.
Check the virtual machine network settings and also , try to check if you are using a corrupted ISO.
Carlo
04-11-2014 01:48 AM
well, I get the problem when I choose autonegotiate and the server cannot autonegotiate. So I try to not choose autonegotiate and this problem not occured at install.
Please check your ethernet already assign at VM
