ESXi version for CUCM 11.5
Scott Hanson
Level 3
Level 3
looking for a document that spells out the minimum version needed for ESXi to host CUCM 11.5
All replies rated.
Thanks in advance!
Rob Huffman
Hi Scott,
The min/max versions are listed below;
Version 11.5(1)
Supported Versions of VMware vSphere ESXi= 5.0 U1, 5.1, 5.5, and 6.0 ; HX TRC 6.0 only
From;
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html
Cheers!
Rob
7 Replies 7
Rob Huffman
Hi Scott,
Version 11.5(1)
From;
Cheers!
Rob
Hi ,
I'm wondering about this statement for ESX version: "HX TRC 6.0 only"
Does it mean, that if I'm using a HX in setup, that is not listed as TRC (I think there is only 1), I can use ESX 6.5 ?
Kamil
Hi Rob,
Kamil
I think that is an outdated version. Kindly check this document:
Version 11.5
Supported Versions of VMware vSphere ESXi= 5.0 U1, 5.1, 5.5, 6.0, 6.5 (For application fresh installs on ESXi 6.5 (VMFS5 or 6) and/or vCenter 6.5, use minimum OVA file version cucm_11.5_vmv8_v1.1.ova. Does not apply to ESXi version upgrades.); HX TRC 6.0 only
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html
Is there any expected timeline for support of ESXi 6.7? Our compute team is starting to work on migrating systems to this version, but I don't see it on the supported list for Call Manager & most of the other UC applications yet.
Roadmap questions cannot be answered here as that's NDA material, if I recall correctly, James Arias touched the subject in a recent VoE on platforms.
If you're not with a Cisco partner, you would need to ask via your SE/AM.
java
if this helps, please rate
Thanks Jaime
I understand - I'll redirect the question to the appropriate channel.
