EVM-HD-8FXS/DID Rejected on ISR 2900
p-vincent
Hi All,
I have a Cisco 2911 with an EVM-HD-8FXS/DID card. The card was recognized at the first boot and I was able to see the voice-ports etc.. After a reboot the card isn't recognized anymore and I have the following messages in the logging:
*Jan 20 15:07:47.611: %IOCTRL-3-I2C_ERROR: I2C R/W Error accessing device on io-controller I2C bus 1 : I2C Slave Device not found,  -Traceback= 0x215C2724z 0x2140532Cz 0x21937998z 0x21937AB8z 0x2140558Cz 0x21938E64z 0x21312E38z 0x21315998z 0x21134744z 0x21133E48z 0x213D68BCz 0x2343E4E0z 0x2343E5C8z 0x2226B6D8z 0x2226B978z 0x233DEA40z
*Jan 20 15:07:52.455: %PA-3-NOTSUPPORTED: PA in slot1 (Unknown (type 0)) is not supported on this image/licenses enabled. Please issue "show diag" CLI command to display the PA information, verify it is supported and, if applicable, ensure the correct license key is installed. A newer image version or license key may be needed.
The "show diag" command show me the following output:
sh diag
Slot 0:
        C2911 Mother board 3GE, integrated VPN and 4W Port adapter, 7 ports
        Port adapter is analyzed
        Port adapter insertion time 00:45:12 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC14320C7R
        Hardware Revision        : 1.0
        Part Number              : 73-11833-05
        Top Assy. Part Number    : 800-30797-02
        Board Revision           : B0
        Deviation Number         : 111354
        Fab Version              : 03
        Product (FRU) Number     : CISCO2911/K9
        Version Identifier       : V02
        CLEI Code                : CMMBR00ARA
        Processor type           : C1
        Chassis Serial Number    : FCZ143871BC
        Chassis MAC Address      : 1cdf.0f6e.f6c0
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 34 33 32 30 43 37 52 40
          0x10: 06 18 41 01 00 82 49 2E 39 05 C0 46 03 20 00 78
          0x20: 4D 02 42 42 30 88 00 01 B2 FA 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 31 31 2F 4B 39 89 56 30 32 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 52 30 30 41 52
          0x50: 41 09 C1 C2 8B 46 43 5A 31 34 33 38 37 31 42 43
          0x60: C3 06 1C DF 0F 6E F6 C0 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 25 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal power Supply information
        Top Assy. Part Number    : 341-0235-03
        Deviation Number         : 0
        PCB Serial Number        : AZS141500DX
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V01
        Product (FRU) Number     : PWR-2911-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E5 DF 45 01 55 00 EB 03 88 00 00 00
          0x10: 00 C1 8B 41 5A 53 31 34 31 35 30 30 44 58 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 31 20 CB 8B 50 57
          0x30: 52 2D 32 39 31 31 2D 41 43 C6 8A 30 30 30 30 30
          0x40: 30 30 30 30 30 F3 00 59 41 00 BE 42 00 05 F8 00
          0x50: 50 01 F4 17 2B 02 EE 1A 7A 03 E8 1B 65 04 E2 1C
          0x60: 47 05 DC 1C C9 06 D6 1D A3 07 D0 1E 54 08 CA 1E
          0x70: E6 09 C4 1F 5C 0A BE 1F BF 0B B8 20 12 0D AC 20
          0x80: 92 0F A0 20 F0 11 94 21 38 13 88 21 6B 17 70 21
          0x90: AE 1B 58 21 D3 1F 40 21 E0 23 28 21 DE 27 10 22
          0xA0: 56 42 41 30 FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        16-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11576-03
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        : FOC1428091S
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-16
          0x00: 04 FF 40 05 D8 41 01 00 82 49 2D 38 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 34 32 38
          0x20: 30 39 31 53 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 31 36 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        PVDM Slot 1:
        64-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11809-03
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        : FOC14321ZCR
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-64
          0x00: 04 FF 40 05 DB 41 01 00 82 49 2E 21 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 34 33 32
          0x20: 31 5A 43 52 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 36 34 20 20 20 20 20 20 20
        WIC Slot 0:
        VIC2 - BRI-NT/TE Voice daughter card (2 port)
        Hardware Revision        : 1.1
        Top Assy. Part Number    : 800-21861-03
        Board Revision           : B0
        Deviation Number         : 0-0
        Fab Version              : 02
        PCB Serial Number        : FOC12181EYV
        RMA History              : 00
        Product (FRU) Number     : VIC2-2BRI-NT/TE
        CLEI Code                : CNUIAVZAAA
          0x00: 04 FF 40 00 51 41 01 01 C0 46 03 20 00 55 65 03
          0x10: 42 42 30 80 00 00 00 00 02 02 C1 8B 46 4F 43 31
          0x20: 32 31 38 31 45 59 56 03 00 81 00 00 00 00 04 00
          0x30: CB 8F 56 49 43 32 2D 32 42 52 49 2D 4E 54 2F 54
          0x40: 45 89 56 30 32 20 C6 8A 43 4E 55 49 41 56 5A 41
          0x50: 41 41 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 1:
        Board Revision           : B0
        Fab Version              : 02
        PCB Serial Number        : FOC11383K4Q
        RMA History              : 00
          0x20: 31 33 38 33 4B 34 51 03 00 81 00 00 00 00 04 00
Slot 1:
        Unknown (type 0) Port adapter
        Port adapter is disabled
        Port adapter insertion time unknown
        Hardware revision 0.0           Board revision UNKNOWN
        Serial number     0             Part number    00-0000-00
        Version Identifier              FRU Part Number
        Test history      0x0           RMA number     00-00-00
        EEPROM format version 0
          0x00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
          0x30: 00 00 00 00 00 00 00 00 00 00 00 00
And the "show version":
sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 03:32 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
VG_VOTTEM_01 uptime is 46 minutes
System returned to ROM by reload at 15:05:44 UTC Thu Jan 20 2011
System image file is "flash:c2900-universalk9-mz.SPA.150-1.M3.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. CISCO2911/K9 (revision 1.0) with 471040K/53248K bytes of memory.
Processor board ID FCZ143871BC
3 Gigabit Ethernet interfaces
4 ISDN Basic Rate interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
254464K bytes of ATA System CompactFlash 0 (Read/Write)
If
Cisco
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FCZ143871BC
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            uck9          Permanent     uck9
data          None          None          None
Can someone help me to re-activate this module ?
br,
p-vincent
dksingh
You have UC license so does not appear to be related to license or IOS ver.
EVM-HD-8FXS/DID is supported on 2911:
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/aag_c07_563807.pdf
Don't think there is much you can do other than replacing the module but see if
any of following helps:
- Reseating the module (powed down first)
- Trying it in another router chasis
- Checking daughterboards installed to make sure they are supported as per above doc.
-I allready tried resetting the module but that didn't help
- trying it in another chassis will be difficult, as the router is placed on the other side of the country..
-Daughterboards are supported, I doublechecked with my distributor.
Thanks for your answer, I think there will be no other solution than replacing the module..
Hi!
Did you figure out the issue?
Or have you just replaced with another EVM-HD-8FXS?
Yes, the module was replaced to solve the problem..
