Bookmark
Subscribe
17538
Export list of extensions and users from CUCM
mramirez-t
We're running CUCM v10.5.  I need to get a list of all users with their extensions.  Is there an easy way to do that?
Make sure you're logging to the PUB if you have more than one server.
java
if this helps, please rate
7 Replies 7
Georgios Fotiadis
You could use Bulk Administration > Phones/Users > Export.
Georgios
Please rate if you find this helpful.
I saw Bulk Administration in a Youtube video about bulk exporting info, but my Unified CM Administration doesn't have Bulk Administration as a menu option.  I only have:
System
Call Routing
Media Resources
Advanced Features
Device
Application
User Management
Help
Try log-in as administrator. The user you are using to log-in does not have right to use Bulk Admin.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/accm-861-cm/a02mla.html
Georgios
java
How can you download the exported report from the job scheduler?
Status is ready, job status is completed but not download option. Thanks
EDIT:
Found the option in the separate tab in bulk administration (Upload/Download files)
Go to Call Routing Tab
Click on Route Plan Report,after loading,look at the top right where you will see "View in File".
Click the go button.
You will receive the list in excel form.
Cheers!!!
