Export PHone switch/port information CUCM 8.5
StephRoss
Is there a way to export the phones and their respective switch/ports from CUCM 8.5?
I've looked through the bulk admin tool options, but no luck.
I am looking for the Network Switch/Port information for each phone. The same information you can see when
choosing the i.p. hyperlink from the phone/device and subsequently the network link from that page....
CDP Neighbor Device ID
CDP Neighbor IP Address
CDP Neighbor Port
FYI, all our swiches are Cisco. Am trying to get an inventory of switches. updates have not been done in CER and there is no accurate inventory anywhere.
5 Replies 5
Jaime Valencia
No, that info is nowhere to be found within CUCM. You would need to look into 3rd party products that actually go to each phone to gather information, and I'm not even sure if those would get that for you.
java
if this helps, please rate
moyo oyegunle
If you don't mind the effort you can cross reference information from each switch using sh cdp neighbors and the device phone list from CUCM and use MAC address as a matching key in excel.
Charles Hill
Hey ,
Good news is that Serialgrabber which is a FREE 3rd party app that will grab Phone info as well as the switch and switchport info.
Bad news, I believe it only supports older phone models, like the 7940 and 7960s.  They may have a newer version that will locate the newer phones, but I haven't seen it.
The other option, which Moyo suggested, is to manually walk your network with cdp and locate all phones and assoicated switchports.
Hope this helps.
Please rate helpful posts.
Thanks.
Hi StephRoss,
Recently we downloaded 0.11 version of SourceForge and were able to discover 9951/6921/7911/7906/7941 phones along with IP address/Mac address/Phone Load/Phone DN/switch port/serial number of phone .Make sure phone is regsitered to call manager to get the details.
regds,
aman
StephRoss
Thank you All.
I was afraid it would be a tedious process.  But that's ok. at least I'll get a good starting inventory when I'm done.
