IP Telephony and Phones
Labels
Currently using Attendant Console 8.6. When the Receptionist transfers an external call to a internal phone using the AC, a 5 digit extension displays on our 7965G's. When answering the call, the telephone number will then display on screen. I was to...
AMUCCI001 by Level 1
  • 384 Views
  • 1 replies
Hi,I have installed Cisco CUEAC 9.1, every thing synced but Queue DDI option is not available. I tried to use Name as DDI but didn't work. But in Version 8.6 we have DDI Queue option right under Name option. I need support on this issue urgently. Reg...
I am starting to study for my ccnp-voice.  In my experience the best way to learn something is to build it and use it.  Does anyone know what kind of setup I need to hook my home fios voice into a CME or CUCM setup?  Like would I be able to wire it i...
We've just installed our first ATA190, and discovered that PDQ & Fax machines dial too quickly for the ATA and it looses digits. e.g. If the PDQ or fax machine dials 01632 123456, the ATA only registers 0162 1356 Has anyone seen something like this b...
I shut down subsctiber and phone will not register to publisher.only one tftp on subscriber. This are all working phones. What can be the issue? Do i need to enable both tftp services.since the phone already have the firmware it should not need the t...
Hello everyone, i have some trouble with 4 cisco ip phone 7821 who renew ip address after reboot, paste the log of the phone next:4667 NOT 14:58:14.901708 DHCP-dhcpWriteResolv(): /etc/resolv.conf points to ../tmp/.resolv.conf.dhcp, need to change4668...
Does anyone know of any concerns, issues, problems, or hidden gotchas that have been experienced with creating a VRF for a VoIP network?  What I would actually like to do is place everything (except the media gateways) in a VRF and firewall it.  Thus...
When I set my 7940 to CFwdAll it forwards both my primary line and my secondary line, I want it to only forward the primary line.I've been told that it's supposed to only forward the primary line and not the secondary but apparently something is diff...
drak23001 by Level 1
  • 506 Views
  • 4 replies
There were some IP Phone 7911 shared the same external number to PSTN and worked properly before.After 7911 has been replaced by 6941, only 1 phone can dial out to PSTN at the same time, the others can't.When the IT crew checked on the configuration ...
c1szhibin by Level 1
  • 546 Views
  • 2 replies
