exporting voicemail user info from CM
ryanwhalley
Were having a small issue with VM, users in CM have a voicemail profile appiled and they are not in unity, we need to ID these users.
What I'd like to do is export all the users in CM that have VM on there profile and then compare that to unity. We did try an export but we didnt get the correct information. Can anyone point me in the right direction for what CLI command I should be running to generate this info?
Chris Deren
Use BAT phone export.
Though keep in mind that there is always a default VM profile, so to restrict the Messages button from calling voicemail system you need to apply NoVoiceMail profile rather than keeping it at none as that will invoke the default profile.
HTH,
Chris
