09-29-2015 09:26 PM - edited 03-17-2019 04:25 AM
Hello, we have Expressway with "One lan" topology
Expressway - C {192.168.1.187}
Expressway - E {192.168.1.188}
Expressway - E have access to internet via gateway cisco 3825
sh run
ip nat inside source static 192.168.1.188 195.112.xxx.xxxx
Jabber client outside register on CUCM - it's OK , but not inbound\outbound voice activity, RTP .
Why?
p.s Firewall disabled
diagnostic_log_expressway-c_2015-09-30_03-02-58.zip log , and pcap file from Expressway-C.
Please help me (((
12-03-2015 05:47 AM
12-03-2015 06:14 AM
Did you configure nat reflection? Did you point expwc to the global ip/natted ip of expressway-e? Did you use static nat on expwe? have you disabled sip inspection on firewall?
12-03-2015 07:07 AM
I am configured nat in cisco IOS 3945
ip nat inside source static 10.10.1.56 195.112.xxx.xxxx
12-03-2015 07:23 AM
Please read the deployment guide. You need to configure nat reflection. Your expwc must be able to reach the global ip of your expwe
12-03-2015 07:33 AM
Do you have any example of nat reflection in cisco IOS?
12-03-2015 07:49 AM
unfortunately I dont. You can post this on the seucrity forum, I am sure there will be people who can help there
02-17-2016 10:49 AM
Hi Guys,
My jabber with MRA without VPN work fine.
12-03-2015 06:28 PM
If you have split DNS and just a single router for internet, I would advise to setup the second NIC, option keps are now included as part of collab edge solutions. Saves passing the ExpC <> ExpE traffic through a firewall/router and comes in handy for troubleshooting.
