Expressway-E, CUCM 10.5 Telephony Services not work
Sergey Ptushkin
Hello, i need help.
We do have a CUCM unrestricted version installed v 10.5
 unrestricted version not support "security profile" with TLS.
 In the manual "Deployment MRA Guide Expresswway 8.5" stated that "Security profile" must be.
My jabber client can't connect to CUCM across Expressway-E, telephony service - not work. But IM&P work fine. See. cucm.png
Is it compatible with Expressway-E and Expressway-C ? or should we reinstall the CUCM with restricted version?
I coudln't find the info.
Without TLS security will not work?
May be i can used as a non-secure connection , without TLS security profile, only TCP or UDP ?
How to set up non-TLS connection TCP or UDP to CUCM without "TLS security profile" across Expressway-E ?
Jaime Valencia
Not sure why my previous reply, and yours, were deleted, as I mentioned, that is only applicable for mixed mode security environments, if you're not going to be doing that, you do NOT require the security profiles.
java
if this helps, please rate
I have this log in my Expressway-E and C.
But my cert - is correct.
tvcs: UTCTime="2015-09-29 13:13:19,538" Module="network.sip" Level="INFO": Action="Sent" Local-ip="192.168.1.187" Local-port="25048" Dst-ip="192.168.1.188" Dst-port="7001" Detail="Sending Response Code=437, Method=SERVICE, CSeq=16129, To=sip:serviceserver@cucm-rpn-pub, Call-ID=185613babaefba3b@127.0.0.1, From-Tag=20844c57f7336d7b, To-Tag=01fd1ce9d1894495, Msg-Hash=17366240198406948782"
2015-09-29T20:13:19+07:00 tvcs: UTCTime="2015-09-29 13:13:19,537" Module="network.sip" Level="DEBUG": Action="Received" Local-ip="127.0.0.1" Local-port="25047" Src-ip="127.0.0.1" Src-port="22210" Msg-Hash="16936142004695641953"
SIPMSG:
|SIP/2.0 437 Unsupported Certificate
Via: SIP/2.0/TCP 127.0.0.1:5060;egress-zone=DefaultZone;branch=z9hG4bK6fb27b5c454d5ff2f13b08ad646bb70d11331.52fb4c35fcb849edb81b5447421da39c;proxy-call-id=3f011d98-6258-44ed-b874-72da9dc5e3f9;received=127.0.0.1;rport=25047
Via: SIP/2.0/TLS 192.168.1.188:7001;egress-zone=traversal;branch=z9hG4bKb8e88d8bbf7714968e21c917121d278338.e1e4128605b3e9c78d0e1dba696a816e;proxy-call-id=61f815e0-ed3e-423b-bc73-8f0aef1acea9;received=192.168.1.188;rport=7001;ingress-zone=traversal;ingress-zone-id=4
Via: SIP/2.0/TCP 127.0.0.1:5060;branch=z9hG4bK33bbc014b902a7590f5db286fea7c42237;received=127.0.0.1;rport=25001;ingress-zone=DefaultZone
Call-ID: 185613babaefba3b@127.0.0.1
CSeq: 16129 SERVICE
From: <sip:serviceproxy@cucm-rpn-pub>;tag=20844c57f7336d7b
To: <sip:serviceserver@cucm-rpn-pub>;tag=01fd1ce9d1894495
Server: TANDBERG/4130 (X8.5.1)
Content-Length: 0
