Call Manager 5.1 upgrade error
tiger_401
Dear All,
I am upgrading my call manager from System version: 5.1.3.2000-3 to 6.1.4 but i am not able to upgrade it, its giving me an error.
there is no hardware issue. hardware is compliable.
the file i am trying to upload is UCSInstall_UCOS_6.1.4.1000-10.sgn
Can you please guide me to solve this problem
I will be very grateful to you if you can help me in this issue.
Please find attached the screenshoot for your consideration
Thanks a lot in advance.
regards
Malik
Rob Huffman
Hi Aman,
He can use the download version of the sgn.iso The note on
the download page is really just a "Heads up" to remind people that
a Software feature license would be required. Many people in the past
would do the upgrade without securing the licenses and of course the
Callmanager service wouldn't start. So Cisco started putting up the
warning flag on the download page to remind people.
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
13 Replies 13
Aman Soi
Hi Malik,
I was just checking the software compatibility for upgrade which says that it is possible to upgrade but when I login on Cisco Site for downloading the patch , it says
Cisco Unified Communications Manager 6.1(4) part 2 of 2 (non-bootable) - Upgrade from 6.1(2x), 6.1(3x)
That is the reason u a re getting this message.
regds,
aman
Thanks a lot for the reply Aman, please gudie me what should i do now.
i have this file as well  UCSInstall_UCOS_6.1.5.12900-7.sgn
will it work
Thanks a lot.
Malik
Rob Huffman
Hi Malik,
Just to add a note to the good tips from my friend Aman (+5)
The 2 files, when combined should have a .sgn.iso file extension;
Upgrading to Unified CM Release
6.1(4) by Using the UCSInstall File
Because of its size, the UCSInstall iso file, UC
OS_6.1.4.1000-10.sgn.iso, comprises two parts:
UCSInstall_UCOS_6.1.4.1000-10.sgn.iso_part1of2
UCSInstall_UCOS_6.1.4.1000-10.sgn.iso_part2of2
Procedure
Step 1
From www.cisco.com, download the two UCSInstall files.
Step 2
Execute one of the following commands to reunite the two parts of the file.
Note
The 6.1.4.1000-10 build represents a non-bootable ISO that is only useful for upgrades. You cannot use
it for new installations.
a.
If you have a Unix/Linux system, cut and paste the following command from this document into the
CLI to combine the two parts:
b.
If you have a Windows system, cut and paste the following command from this document into the
command prompt (cmd.exe) to combine the two parts:
Step 3
Use an md5sum utility to verify that the MD5 sum of the final file is correct.
d3557a8c0a2895be4085189537356dfd  UCSInstall_UCOS_6.1.4.1000-10.sgn.iso
http://www.cisco.com/web/software/282074295/27086/cucm-rel_note-614.pdf
Cheers!
Rob
"Talk about a dream
- Springsteen
Dear Rob,
Thanks for a reply.
Is there a need for a cop file before i proceed further with the upgrade from 5.1 to any other version like 6.1.4 or 6.1.5 or 7.x
regards,
Malik
Dear Rob,
I have followed excalty the same steps but nothing is working.
This is the first time i m facing such kind of an issue.
I dont understand what wrong
Can you please help me sort out this issue
i will be very thankful for your support
Malik
Hi Malik,
The problem which I see is that their is no patch available to upgrdae from 5 to 6.
The patch which is available on Cisco site says u need to have at least 6.x so that u can upgrade to 6.1.X
regds,
aman
Hi Rob,
Thanks for support.
I have checked even for version 6.0 even that is not supported.
http://software.cisco.com/download/release.html?mdfid=280968161&flowid=5324&softwareid=282074295&release=1.1(1)&relind=AVAILABLE&rellifecycle=&reltype=latest
Please just kave a look on attached snapshot.
regds,
aman
Rob Huffman
Hi Aman,
This is a supported upgrade path my friend
Check out (Table 22);
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
The reference that you see has always been on the download pages
and is related to the fact that you need to order 5.x to 6.x upgrades
via PUT so as to receive the proper "License" files. Here is the exerpt
from the release notes;
Upgrading to Unified CM 6.1(4) from Unified CM 4.x and 5.x
If you are upgrading from 4.1.3, 4.2.3, 4.3(2), 5.1.2, or 5.1.3, use the
Product Upgrade Tool(PUT) or  the  PUT for registered customers only
to obtain a media kit and license or purchase the upgrade from
Cisco Sales.
Cheers!
Rob
"Talk about a dream
- Springsteen
Hi Rob,
Thanks a lot for making me clear.Surprisingly,I do not understand why is it like this for some versions where u need to place the order through Cisco while in some cases , u can download the patch directly from Cisco Site
So, Malik has to place an order through PUT provided u have valid ESW /UCSS contract.
regds,
aman
Rob Huffman
Hi Aman,
Cheers!
Rob
"Talk about a dream
- Springsteen
Dear Aman/Rob,
Thanks for your usual great support.
I really appreciate.
Is there any other way we can proceed with the installation.
Your consideraiton in this regard will highly be appreciated.
Malik
i downloaded this patch cisco-ipt-k9-patch5.1.3.8000-4.tar.gz.sgn
now i m uploading them to both pub and sub
Malik
Malik,
I know this is an old thread, and is a complete long shot, but is there any chance you have the cisco-ipt-k9-patch5.1.3.8000-4.tar.gz.sgn on hand somewhere?  We have an outdated CallManager cluster, and one of our nodes died, and now trying to rebuild, I can't download this file anymore.  The cisco site no longer allows you to download 5.x callmanager.
You're help would be greatly appreciated!!!
Chris
