Extension list on VG224 Gateways
r.robins
Can anybody out there tell me where in CM 6.1 I can list the extensions configured on over 60 VG224 voice gateways.
If I do a search under Device>Phone> none of the configured extensions are displayed.
Jaime Valencia
depends on protocol being used, what are u using?
if u know the DNs or range use the route plan report to find where they are
java
if this helps, please rate
java
