02-01-2011 02:09 AM - edited 03-16-2019 03:11 AM
Hi after upgrading the callmanager from 7.1 to 8.0.3 i found extension mobility not working. I was told i had been hit by bug CSCsy76489 by cisco tac. I cant find any information on this particular bug on the tool kit since its still internal. I wonder if anyone from cisco out there can give me some feed back on the status of this bug?
Colin
Solved! Go to Solution.
02-01-2011 02:21 AM
The bug just describes the problem you are facing and mentions about a workaround:
-> In the CUCM OS Administration page, re-generate the "Tomcat" certificates in all the nodes in the cluster. When the certificate is re-generated, the new certificate will be updated in the DB and CertMgr component should create the tomcat-trust.keystore file.
-> Restart Tomcat in all the nodes.
02-01-2011 02:21 AM
02-01-2011 02:25 AM
Thank you for the reply, ill try that tonight and let you know how i get on tomorrow.
colin
02-08-2011 05:33 AM
Your suggestion fixed my issue, many thanks
colin
07-01-2012 03:34 AM
Hello Guys!!
I am also facing the same issue. I have upgraded a cluster from 6.1.5 to 8.6.x and all the exisiting phone which used to have extension mobilty enabled is now showing host not found.
Any new phone connected does not have any problem.
If i unsubscriber the phone and Subscribe it back then the issue is resloved. But there are over 1000 phones, is there any work around to resolve this problem? i can subscribe the service again using bulk administration, but i did not find a way to unsubscriber the service using bulk. Any suggstion
