Hello
Do we need a specific IOS Version for Enabling a Phone to use Extension Mobility in CallManager Express, currently I got CME running on V 4.1
i noticed "voice user-profile 1" command not working with my CME IOS version
ST
Solved! Go to Solution.
Hi Saquib,
When you upgrade the IOS the CME version is upgraded alongside (automagically) as well
I will leave the recommendations to someone who knows more about all the recent releases than I.
Cheers!
Rob
Hi Saquib,
Here we go
•Cisco Unified CME 4.2 or a later version.
•To use the web-based Cisco Unified CME GUI to configure personal speed dials on an Extension Mobility phone, Cisco Unified CME 4.2(1) or a later version must be installed.
•To use the phone user interface to configure personal speed dials directly on an Extension Mobility phone, Cisco Unified CME 4.3 or a later version must be installed.
•SIP phone support is available with Cisco Unified CME 8.6 or a later version.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmemobl.html#wp1091745
This would mean a minimum IOS of 12.4(11)XW9
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Cheers!
Rob
Thanks Rob.
Does it means I have to upgrade IOS of the router as primary step and then upgrade the CME software, please do clarify this.
I got (C3825) running Version 12.4(15)T12. What is the recommended IOS for C3825
thanks again
ST
Hi Saquib,
Cheers!
Rob
Thanks Rob
