Extension Mobility Issue
Nahassamad_2
Hi All,
We are facing an issue in extension mobility/h323 gateway. The callers are getting continuous beep when the user is log-out state(users having DID)This is only happening when calling from extrenally. internally it is fine, give busy tone. Any thoughts..
CCM ver 6.1.5 - VG PRI H323.
Jaime Valencia
I'd start by checking CSS for inbound calls for logged in and logged out profiles
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
