12-15-2010 05:00 AM - edited 03-16-2019 02:26 AM
I have configured Extension mobility and can able to login using user ID and PIN .
Only thing I want to know ,after logging in, is all feature including outgoing restriction is applied on phone where user logged in.
I tried on one extension (Extn No: 6786) having no outgoing facility and I logged in using my user ID and PIN and my extension 6633 have local outgoing facility.After logging in I was unable to make outgoing call but when i change out going restriction of ext 6786 to local it was working.
Please help me,if we can able to assign outgoing restriction with Extension mobility.
Thanks & regards
Satish
12-15-2010 05:59 AM
Should follow the DN CSS.
12-15-2010 06:03 AM
The ability to make calls still depends on the combination of the CSS from the line and the device.
There are many ways to configure this, you can configure blocking all calls if no EM is logged in.
Local calls or internal calls.
Any calls and then apply restrictions with the EM Line CSS, etc
Look at your CSS from EM line and device you're using, the problem is there.
Review this 2 topics for further info:
For recommendations on how to set the line and device calling search spaces, refer to the sections on Building Classes of Service for Unified CM with the Traditional Approach, and Building Classes of Service for Unified CM with the Line/Device Approach.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/dialplan.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
