IP Telephony and Phones
watch here Journey banner_1
Labels
Hi all,         I have a confusion regarding DID (direct inwards dialing).                  when an organization purchases a range of numbers for DID/DOD, does the organization have to use that range for internal and external purposes or else can we ...
I am trying to connect a Plantronics HW261N headset to a 7942 deskphone using a Plantronics adapter. I assume it should be as easy as connecting the headset/adapter to the back of the phone, but apparently not. There is no sound coming through the he...
I have below problem. I have added bulk speed dial list in CME which  has got entries like this.The prefix is #7933,934481800001,Test  user,hideIn above by dialing #7933 user will reach  the phone number 81800001 and 9344 is the destination pattern o...
Asim ali by Level 1
  • 2147 Views
  • 10 replies
hello,we would like to do a tranfer with asistant. is mean if im operator and recive a external call I can ask first to the destination (my collage) if they are acept the call, if they acept I can do the transfer if they not acept I can tell to the e...
Has anyone ran up on this error?Jan 18 22:44:46.748: //-1/xxxxxxxxxxxx/MGCP/mgcp_check_hostname(8786):[lvl=0]Try ing to validate endpoint name. I tried to look it up in cco, but no luck. I have a 3845 with 12.4.11 t1 code. Thanks
pharden by Level 1
  • 682 Views
  • 2 replies
