Extension not showing in Corporate Directory for IP Phones
fuhrersk8
Level 3
Level 3
                   Hi guys,
     Extension are not showing when the directories button is pressed on phones 7942. When pressed, and then select Corporate Directory, only the names appear but no extensions. I checked under Enterprise Parameters on CUCM8.5 and the Show Extension in Directory flag is set to True. Also under Device --> Device Settings --> Phone Services the Corporate Directory service is configured and Enterprise Subscription is True for this service.
Please advice. Thanks in advanced guys!
If you're replying based on the Primary Extension field which has a dropdown menu, that's not what I'm asking.
Does the user has his DN under the Telephone Number field if you look at it under end users??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
Do you have the DNs configured under the end users??
java
java
Hello! Yes, the primary extension is associated to each user.
java
java
Got it! Excellent! Thanks a lot.
