Extension priority to override DND
MuhammadSaad_2
I want to achieve below scenario.
I have Phone A which is on DND. If Phone B or Phone C will call it should ring otherwise any other call from any extension should flash only.
How i can achieve this. I have Cisco CUCM 9.1
Thank you
Jaime Valencia
That is not possible, we don't have white/black lists to do that, it's all, or none.
java
if this helps, please rate
But through MLPP i think its possible b/c as per Document MLPP surpass the DND enable phone.
But not able to configure b/c i have dx650 and 9971 P Phones.
Any idea!!
Thank You
