PSTN to CUC AA no audio after call transfers and answers
sam saeed
This is the lowdown when a caller from the outside (SIP TRUNK) calls into the AA in CUC and it transfers to the Hunt pilot in CM the call connects but no audio on both sides.  Just to see if it was an issue with inbound calls I changed the translation rule to bypass the AA and go straight to my extension. Call connects and audio both sides. This is a new install so it never worked before. Yesterday calls transferred from the AA weren't transferring to the pilots or phones which was pain to figure out. I realized I needed to add pstn partitions to the voicemail CSS. Thats what I get for assuming the configuration guide on setting up AA on CUC mentioned everything I needed to know to get it working.
It looks like I'm very close to get this up and running I just need calls connected through AA transfers to have audio and I'll be good to go. To add there is audio when I call the AA from within the network and the call connects through a transfer. It is also a CUCM CUC sccp integration.
This is the call flow
SIP TRUNK -> V Gateway 2911 -> CUCM -> CUC AA->hander transfers to Hunt Pilot
I don't think it would be a CSS issue since calls do connect its some sort of RTP issue but I can't wrap my head around why it only doesn't work when AA is doing the transferring versus an outside caller calling directly my extension.
Would a pattern in the restricted table in CUC prevent rtp from flowing?
5 Replies 5
Shadi Shami
Level 7
Level 7
David,
As a quick suggestion try checking mtp required check box under the sip trunk configuration on cucm, make sure the trunk has an MRGL contains MTP.
To figure out where the issue is exactly, we need (debug ccsip messages) and (show run) from the voice gateway together with Detaild CUCM traces.
Thank you,
Shadi
@Shadi,
Ok I'll try enabling MTP software on the cucm and see if that'll do it. What do I need to run to get the cucm traces? I know my way around the cucm but this is the first time I've been given a full build out I am more of CME smb guy. So I am learning a boatload of stuff through these hiccups.
@Lea
Yes I know more often then not no audio is usually a routing/nat issue depending on the scenario. But I can't make sense why it works if I change the translation pattern on the GW pointing to my extension versus the call getting processed by AA and handing it back to CUCM.
I confirmed that I get audio if I call the AA within the network on a deskphone, transfer and connects. I can ping from GW and cuc os admin to my extensions. Its not an isolated issue to one phone this issue effects all of the internal phones.
Hi David,
You said the calls are working if you dial the phone directly bypassing the AA. From your CUBE, I need to see the output of the command 'sh call act vo brief called-number xxxx' in both cases (without AA and with AA).
@Mohammed
I'm thinking my issue may be related to a software bug. The CUCM version my manager downloaded was 9.1(1.10000.11)
Cisco Bug: CSCus91721 - No audio on call through SIP trunk to CUBE due to MTP hanging
one of the effected versions: 9.1(1.10000.11)
WITH AA
TEST2911#
TEST2911#show call act voi bri
Telephony call-legs: 0
SIP call-legs: 2
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 2
1ED4 : 691 14216390ms.1 (16:36:31.625 UTC/EST Sat Oct 3 2015) +450 pid:9 Answer 9085776815 connected
 dur 00:01:11 tx:1210/193600 rx:1189/185560 dscp:0 media:0 audio tos:0xB8 video tos:0x0
 IP 216.86.41.7:30666 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No
 media inactive detected:n media contrl rcvd:n/a timestamp:n/a
 long duration call detected:n long duration call duration:n/a timestamp:n/a
1ED4 : 692 14216400ms.1 (16:36:31.635 UTC/EST Sat Oct 3 2015) +430 pid:7 Originate 2010 connected
 dur 00:01:11 tx:1189/185560 rx:1203/192480 dscp:0 media:0 audio tos:0xB8 video tos:0x0
 IP 10.10.10.15:4000 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No
SIP call-legs: 2
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
TEST2911#
TEST2911#
WITHOUT AA
SIP call-legs: 2
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
1EDB : 693 14386840ms.1 (16:39:22.075 UTC/EST Sat Oct 3 2015) +5860 pid:9 Answer 9085776815 active
 dur 00:00:01 tx:69/11040 rx:60/9600 dscp:0 media:0 audio tos:0xB8 video tos:0x0
 IP 216.86.41.5:6320 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No
1EDB : 694 14386850ms.1 (16:39:22.085 UTC/EST Sat Oct 3 2015) +5840 pid:7 Originate 114 active
 dur 00:00:01 tx:60/9600 rx:69/11040 dscp:0 media:0 audio tos:0xB8 video tos:0x0
 IP 10.10.10.15:26204 SRTP: off rtt:0ms pl:0/0ms lost:0/0/0 delay:0/0/0ms g711ulaw TextRelay: off Transcoded: No
SIP call-legs: 2
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 2
I looked through the call trace using Translator X on the PUB (using AA) and noticed this during the time that I punched the extensions during the AA playback:
04844546.001 |14:19:29.776 |SdlError |SsMediaDisconnectedInd                 |wait                           |ForwardManager(1,100,193,1)      |                                 |                                         |Error:  Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
Also how do I upload the traces on here. I tried but it said txt.gz extensions can't be uploaded.
This is the show run:
TEST2911#sh run
Building configuration...
Current configuration : 10229 bytes
! Last configuration change at 16:53:38 UTC/EST Sat Oct 3 2015 by
version 15.2
hostname TEST2911
boot-start-marker
boot system flash1:c2900-universalk9-mz.SPA.152-4.M4.bin
boot-end-marker
logging buffered 10000000
no aaa new-model
clock timezone UTC -5 0
clock summer-time UTC/EST recurring
ip cef
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp excluded-address 192.168.2.1 192.168.2.10
ip dhcp excluded-address 192.168.3.1 192.168.3.10
ip dhcp excluded-address 192.168.3.101 192.168.3.255
ip dhcp pool voice
 network 10.10.10.0 255.255.255.0
 default-router 10.10.10.1
 option 150 ip 10.10.10.242
ip dhcp pool Public_WIFI
 network 192.168.3.0 255.255.255.0
 default-router 192.168.3.1 255.255.255.0
 dns-server 209.244.0.3
ip domain name test.local
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip name-server 151.198.0.38
ip name-server 151.202.0.85
ipv6 multicast rpf use-bgp
no ipv6 cef
voice-card 0
 dsp services dspfarm
voice service voip
 ip address trusted list
  ipv4 X.X.X.X
 mode border-element
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 no supplementary-service sip moved-temporarily
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  bind control source-interface GigabitEthernet0/0.10
  bind media source-interface GigabitEthernet0/0.10
  registrar server expires max 1200 min 300
  early-offer forced
  midcall-signaling passthru
voice class media 1
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice class custom-cptone JOIN
 dualtone conference
  frequency 1000 2000
  cadence 100 100 100
voice class custom-cptone LEAVE
 dualtone conference
  frequency 600 800
  cadence 100 100 100
voice translation-rule 1
 rule 1 /2016....../ /2010/
voice translation-rule 2
 rule 1 /^911$/ /911/
 rule 2 /^8\(.*\)/ /\1/
voice translation-rule 3
 rule 1 /^.*/ /20168...../
voice translation-rule 4
 rule 1 /^8(.......)$/ /201\1/
 rule 2 /2010/ /20168...../
 rule 4 /^8(...)$/ /2016\1/
 rule 5 /^8(.*)/ /\1/
voice translation-rule 5
 rule 1 reject /9549783900/
voice translation-rule 6
 rule 1 /^201\(.*\)/ /8\1/
 rule 2 /\(..........\)/ /81\1/
voice translation-profile BLOCKED-INCOMING
 translate calling 5
voice translation-profile CUE_Voicemail/AutoAttendant
 translate called 1
voice translation-profile PSTN_CallForwarding
 translate redirect-target 4
 translate redirect-called 4
voice translation-profile PSTN_Outgoing
 translate calling 3
 translate called 2
voice translation-profile filter_Incoming
 translate calling 6
license udi pid CISCO2911/K9 sn xxxxxxxx
hw-module pvdm 0/0
redundancy
interface Loopback0
 ip address 1.1.1.1 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 no ip address
 duplex auto
 speed auto
 description $FW_INSIDE$
 encapsulation dot1Q 1 native
 ip address 10.1.1.201 255.255.255.0
 description $FW_INSIDE VOICE NETWORK$
 encapsulation dot1Q 10
 ip address 10.10.10.1 255.255.255.0
interface GigabitEthernet0/0.50
 description $DATA_NETWORK$
 encapsulation dot1Q 50
 ip address 192.168.2.1 255.255.255.0
 ip helper-address 192.168.2.240
interface GigabitEthernet0/0.51
 encapsulation dot1Q 51
 ip address 192.168.3.1 255.255.255.0
 ip access-group VLAN51 in
interface GigabitEthernet0/0.52
 description MANAGEMENT
 encapsulation dot1Q 52
 ip address 192.168.4.1 255.255.255.0
interface GigabitEthernet0/1
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.2.251
control-plane
ccm-manager music-on-hold
mgcp profile default
sccp local Loopback0
sccp ccm 10.10.10.241 identifier 1 priority 1 version 7.0
sccp ccm group 1
 associate profile 2 register R2-CONF
 associate profile 1 register R1-XCODE
dspfarm profile 1 transcode
 description SiP-AA trial
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 codec g729br8
 codec g729r8
 maximum sessions 6
 associate application SCCP
dspfarm profile 2 conference
 codec g729br8
 codec g729r8
 codec g729abr8
 codec g729ar8
 codec g711alaw
 codec g711ulaw
 maximum sessions 2
dial-peer voice 1 voip
 description **Outgoing Call to SIP Trunk**
 translation-profile outgoing PSTN_Outgoing
 preference 1
 destination-pattern 8[2-9]..[2-9]......
 session protocol sipv2
 session target dns:SIP ISP
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 dtmf-relay rtp-nte
 no vad
dial-peer voice 2 voip
 description **911 Outgoing Call to SIP Trunk**
 destination-pattern 911
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 3 voip
 description **Emergency Outgoing Call to SIP Trunk**
 destination-pattern 8911
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 4 voip
 description **911/411 Outgoing Call to SIP Trunk**
 destination-pattern 8[2-9]11
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 5 voip
 description **Star Code to SIP Trunk**
 destination-pattern *..
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 9 voip
 description **Incoming Call from SIP Trunk**
 translation-profile incoming CUE_Voicemail/AutoAttendant
 call-block translation-profile incoming BLOCKED-INCOMING
 call-block disconnect-cause incoming call-reject
 incoming called-number .%
 dtmf-relay rtp-nte
 codec g711ulaw
 no vad
dial-peer voice 10 voip
 description **International Outgoing Call to SIP Trunk**
 destination-pattern 8011T
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 11 voip
 destination-pattern 81[2-9]..[2-9]......
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 7 voip
 description **CUCM SUB **
 translation-profile outgoing PSTN_CallForwarding
 preference 1
 destination-pattern 2010
 session target ipv4:10.10.10.242
 voice-class codec 1
 dtmf-relay sip-kpml
 no vad
dial-peer voice 8 voip
 description **CUCM PUB **
 preference 1
 session target ipv4:10.10.10.241
 dtmf-relay sip-kpml
 codec g711ulaw
 no vad
sip-ua
 no remote-party-id
 retry invite 2
 retry register 10
 retry options 5
 timers connect 100
 sip-server dns:omitted
 connection-reuse
gatekeeper
 shutdown
call-manager-fallback
 max-conferences 8 gain -6
 transfer-system full-consult
 moh "music-on-hold.au"
 multicast moh 239.1.1.254 port 16384 route 10.10.10.1 10.10.10.241
line con 0
 exec-timeout 61 0
 logging synchronous
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 5041 0
 logging synchronous
 login local
 length 0
 transport input telnet ssh
scheduler allocate 20000 1000
ntp master
ntp update-calendar
end
TEST2911#
Audio issue mostly is cause by routing issue. Are you phone reachable from CUC and Gateway router?
Use ping to confirm.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
