11-29-2016 01:59 AM - edited 03-17-2019 08:48 AM
Please help! when I am trying to call internal extension 8801 from 4411, I am always getting busy signal. This is same for all internal extension to extension calling.
Please Note : 8801 is shared extension between SIP and Skinny phone.
Output of Debug (ccapi inout, dialpeer and ccsip message) attached.
Kindly suggest what is going wrong.
Abhi
Nov 29 09:16:46.108: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:8@10.87.200.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.87.200.109:5060;rport;branch=z9hG4bKPj59Em52oTvY-vqg1IeQ5ozKhWtt4QDN3X
Max-Forwards: 70
From: "SENIOR ELECTRICIAN" <sip:4411@10.87.200.2>;tag=93f2c1d8-6a8f-4edd-84e6-9e00ca990c72
To: sip:8@10.87.200.2
Call-ID: b6155db2-2101-4f05-a99d-f905801f989f
CSeq: 581 INVITE
Allow: PRACK, INVITE, ACK, BYE, CANCEL, UPDATE, SUBSCRIBE, NOTIFY, REFER, MESSAGE, OPTIONS
User-Agent: Cisco-CP3905/9.4.1
Contact: <sip:8FF4-9D3@10.87.200.109:5060>
Supported: replaces,join,sdp-anat,norefersub,extended-refer,X-cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-cisco-monrec,X-cisco-config,X-cisco-sis-5.0.0,X-cisco-xsi-7.0.1
Expires: 180
Accept: application/sdp
Allow-Events: kpml,dialog
Remote-Party-ID: "SENIOR ELECTRICIAN"<sip:4411@10.87.200.2:5060>;privacy=off
Content-Type: application/sdp
Content-Length: 294
v=0
o=- 2212244076 2212244076 IN IP4 10.87.200.109
s=FOXPHONE
t=0 0
a=X-nat:0
m=audio 16390 RTP/AVP 0 8 18 101
c=IN IP4 10.87.200.109
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=sendrecv
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Nov 29 09:16:46.112: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=8, Called Number=8, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8
No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Nov 29 09:16:46.112: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=8, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Nov 29 09:16:46.112: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=NO_MATCH(-1)
Nov 29 09:16:46.112: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=4411, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=40107
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Nov 29 09:16:46.112: //-1/62803940B629/DPM/dpAssociateIncomingPeerCore:
Calling Number=4411, Called Number=8, Voice-Interface=0x0,
Nov 29 09:16:46.112: //-1/62803940B629/DPM/dpMatchSafModulePlugin:
Nov 29 09:16:46.112: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=40107
Result=0 Bitmap=0x0
Nov 29 09:16:46.112: //-1/62803940B629/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=4411
----- ccCallInfo IE subfields -----
cisco-ani=4411
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=8
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Nov 29 09:16:46.112: //-1/62803940B629/CCAPI/cc_api_call_setup_ind_common:
Interface=0x4225814C, Call Info(
Calling Number=4411,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=8(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=FALSE,
Incoming Dial-peer=40107, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=395900
Nov 29 09:16:46.112: //-1/62803940B629/CCAPI/ccCheckClipClir:
In: Calling Number=4411(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Out: Calling Number=4411(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Nov 29 09:16:46.112: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 29 09:16:46.112: :cc_get_feature_vsa malloc success
Nov 29 09:16:46.112: cc_get_feature_vsa count is 1
Nov 29 09:16:46.112: :FEATURE_VSA attributes are: feature_name:0,feature_time:1183772760,feature_id:59219
Nov 29 09:16:46.112: //395900/62803940B629/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=4411(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
Called Number=8(TON=Unknown, NPI=Unknown))
Nov 29 09:16:46.116: //395900/62803940B629/CCAPI/cc_process_call_setup_ind:
Event=0x26188B0
Nov 29 09:16:46.116: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 8
Nov 29 09:16:46.116: //395900/62803940B629/CCAPI/ccCallSetContext:
Context=0x46908490
>>>>CCAPI handed cid 395900 with tag 40107 to app "_ManagedAppProcess_Default"
Nov 29 09:16:46.116: //395900/62803940B629/CCAPI/ccCallSetupAck:
Call Id=395900
Nov 29 09:16:46.116: //395900/62803940B629/CCAPI/cc_api_set_transfer_info:
Transfer Number=, Transfer Reason=0x0
Nov 29 09:16:46.116: //-1/62803940B629/DPM/dpMatchPeersCore:
Calling Number=, Called Number=8, Peer Info Type=DIALPEER_INFO_SPEECH
Nov 29 09:16:46.120: //-1/62803940B629/DPM/dpMatchPeersCore:
Result=Partial Matches(1) after DP_MATCH_DEST
Nov 29 09:16:46.120: //-1/62803940B629/DPM/dpMatchSafModulePlugin:
dialstring=8, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Nov 29 09:16:46.120: //-1/62803940B629/DPM/dpMatchPeersMoreArg:
Result=MORE_DIGITS_NEEDED(1)
Nov 29 09:16:46.120: //395900/62803940B629/CCAPI/ccSetDigitTimeouts:
Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms)
Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
Nov 29 09:16:46.120: //395900/62803940B629/CCAPI/ccCallReportDigits:
(callID=0x60A7C, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Call Id=395900
Nov 29 09:16:46.120: //395900/62803940B629/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 29 Nov 2016 09:16:46 GMT
CSeq: 581 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.4.3.M2
Content-Length: 0
Nov 29 09:16:46.212: //395900/62803940B629/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x4225814C, callID=0x60A7C, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
Enabled=TRUE, Disposition=0x0, Interface=0x4225814C, Call Id=395900
Call Entry(Initial Digit Timeout=10000(ms), Inter Digit Timeout=10000(ms))
Nov 29 09:16:46.220: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:8@10.87.200.2:5060 SIP/2.0
Via: SIP/2.0/UDP 10.87.200.109:5060;rport;branch=z9hG4bKPjfU2nfxq0MqT3JWIb6PvFLD6t.tExAMeO
Max-Forwards: 70
From: <sip:4411@10.87.200.109>;tag=2SVFH5SZ9dl76MlEgYIH20Vhr5oN8lXe
To: <sip:8@10.87.200.2>;tag=989B2018-1974
Call-ID: 62817190-B54B11E6-B62EA1FC-F363F0F5@10.87.200.2
CSeq: 215 NOTIFY
Event: kpml; call-id=b6155db2-2101-4f05-a99d-f905801f989f;from-tag=93f2c1d8-6a8f-4edd-84e6-9e00ca990c72
Subscription-State: active;expires=7199
Allow-Events: kpml, dialog, message-summary, refer
Content-Length: 0
Nov 29 09:16:46.224: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=8, Called Number=4411, Voice-Interface=0x0,
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=8080
Nov 29 09:16:46.224: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Calling Number=8, Called Number=8, Voice-Interface=0x0,
Nov 29 09:16:46.496: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.87.200.109:5060;rport;branch=z9hG4bKPjHKSvz3ncb0YSwQlc67rUD2fBYvvTA9En
Max-Forwards: 70
CSeq: 216 NOTIFY
Content-Type: application/kpml-response+xml
Content-Length: 209
<?xml version="1.0" encoding="UTF-8"?>
<kpml-response version="1.0" xmlns="urn:ietf:params:xml:ns:kpml-response" code="200" text="OK" suppressed="false" forced_flush="false" tag="Backspace OK" digits="8" />
Nov 29 09:16:46.496: //395900/62803940B629/CCAPI/cc_api_call_digit_begin:
Destination Interface=0x0, Destination Mask=0x1, Destination Call Id=-1,
Source Call Id=395900, Digit=8, DigitBeginFlags=0x0,
Rtp Timestamp=0x0, Rtp Expiration=0x0
Nov 29 09:16:46.496: //395900/62803940B629/CCAPI/cc_api_call_digit_end:
Source Call Id=395900, Digit=8, Duration=250,
Xrule Calling Tag=0, Xrule Called Tag=0, Digit Tone Mode=DTMF
Call Entry(Handoff Depth=0)
Nov 29 09:16:46.496: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov 29 09:16:46.496: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 29 09:16:46.496: //-1/62803940B629/DPM/dpMatchPeersCore:
Calling Number=, Called Number=88, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=88
Nov 29 09:16:46.496: //-1/62803940B629/DPM/dpMatchSafModulePlugin:
dialstring=88, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Nov 29 09:16:46.496: //-1/62803940B629/DPM/dpMatchPeersMoreArg:
Nov 29 09:16:46.884: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.87.200.109:5060;rport;branch=z9hG4bKPj6-e2NAVbJVhA2kQXgzXxsij45BLCS1PV
Max-Forwards: 70
CSeq: 217 NOTIFY
Content-Length: 209
<kpml-response version="1.0" xmlns="urn:ietf:params:xml:ns:kpml-response" code="200" text="OK" suppressed="false" forced_flush="false" tag="Backspace OK" digits="0" />
Nov 29 09:16:46.884: //395900/62803940B629/CCAPI/cc_api_call_digit_begin:
Source Call Id=395900, Digit=0, DigitBeginFlags=0x0,
Nov 29 09:16:46.884: //395900/62803940B629/CCAPI/cc_api_call_digit_end:
Source Call Id=395900, Digit=0, Duration=250,
Nov 29 09:16:46.884: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov 29 09:16:46.884: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 29 09:16:46.888: //-1/62803940B629/DPM/dpMatchPeersCore:
Calling Number=, Called Number=880, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=880
Nov 29 09:16:46.888: //-1/62803940B629/DPM/dpMatchSafModulePlugin:
dialstring=880, saf_enabled=1, saf_dndb_lookup=0, dp_result=1
Nov 29 09:16:46.888: //-1/62803940B629/DPM/dpMatchPeersMoreArg:
Nov 29 09:16:47.324: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.87.200.109:5060;rport;branch=z9hG4bKPjxqZAAT1M5Z4CyqUnWwO8Bk-LDQO.bqqR
Max-Forwards: 70
CSeq: 218 NOTIFY
Subscription-State: active;expires=7198
Content-Length: 209
<kpml-response version="1.0" xmlns="urn:ietf:params:xml:ns:kpml-response" code="200" text="OK" suppressed="false" forced_flush="false" tag="Backspace OK" digits="1" />
Nov 29 09:16:47.324: //395900/62803940B629/CCAPI/cc_api_call_digit_begin:
Source Call Id=395900, Digit=1, DigitBeginFlags=0x0,
Nov 29 09:16:47.324: //395900/62803940B629/CCAPI/cc_api_call_digit_end:
Source Call Id=395900, Digit=1, Duration=250,
Nov 29 09:16:47.324: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Nov 29 09:16:47.324: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 29 09:16:47.324: //-1/62803940B629/DPM/dpMatchPeersCore:
Calling Number=, Called Number=8801, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=8801
Nov 29 09:16:47.328: //-1/62803940B629/DPM/dpMatchPeersCore:
Result=Success(0) after DP_MATCH_DEST
Nov 29 09:16:47.328: //-1/62803940B629/DPM/dpMatchSafModulePlugin:
dialstring=8801, saf_enabled=1, saf_dndb_lookup=0, dp_result=0
Nov 29 09:16:47.328: //-1/62803940B629/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20015
2: Dial-peer Tag=40134
Nov 29 09:16:47.328: //395900/62803940B629/CCAPI/ccCallReportDigits:
(callID=0x60A7C, digit_event=0x0, enable=FALSE, consume=FALSE)
Nov 29 09:16:47.328: //395900/62803940B629/CCAPI/cc_api_call_report_digits_done:
(vdbPtr=0x4225814C, callID=0x60A7C, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
Nov 29 09:16:47.328: //395900/62803940B629/CCAPI/ccCallProceeding:
dialstring=8801, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Result=SUCCESS(0)
Result=SUCCESS(0)
1: Dial-peer Tag=40134
2: Dial-peer Tag=20015
Nov 29 09:16:47.328: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=8801, Called Number=8801, Peer Info Type=DIALPEER_INFO_SPEECH
Nov 29 09:16:47.328: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Nov 29 09:16:47.328: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
Nov 29 09:16:47.328: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=8, Called Number=, Voice-Interface=0x0,
Result=NO_MATCH(-1) After All Match Rules Attempt
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Nov 29 09:16:47.328: //395900/62803940B629/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Cause Value=17, Call Entry(Responsed=TRUE, Cause Value=17)
Nov 29 09:16:47.328: //395900/62803940B629/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 486 Busy here
To: sip:8@10.87.200.2;tag=989B24D0-12E2
CSeq: 581 INVITE
Reason: Q.850;cause=17
Content-Length: 0
