10-21-2016 06:05 AM - edited 03-17-2019 08:26 AM
after upgrade of CUCM, on the phones 8851 when a directory number has been dialed (Ex. +1123456789 ), the called number display shows a directory URI (+1123456789@domainname.com).
CUCM version is 11.0.1 and 8851 has Firmware 11.0.1.
How could the directory number display instead of URI?
Solved! Go to Solution.
11-28-2016 05:18 AM
Hi Christian,
yes, it was solved. I don't know how but the 'Always Display Original Dialed Number' parameter under CCM was true.
After changing this parameter to false (default value), the peroblem has been solved.
10-21-2016 06:51 AM
Are these calls traversing a SIP trunk? If so, you can change the blended address setting on the trunk to "Deliver DN only". This should be the default.
Configure SIP Trunks for URI Dialing
Configure SIP trunks in your network to check whether Cisco Unified Communications Manager inserts a
directory number, a directory URI, or a blended address that includes both the directory number and directory
URI in the SIP identity headers for outgoing SIP messages.
Before You Begin
Create the SIP Profile
Procedure
Step 1 In Cisco Unified CM Administration, choose Device > Trunk. The Find and List Trunks window appears.
Step 2 Enter the details for the search criteria and click Find. The Find and List Trunk Configuration window
appears.
Step 3 In the Outbound Calls area, from the Calling and Connected Party Info Format drop-down list, choose
one of the following:
• Deliver DN only in connected party—In outgoing SIP messages, Cisco Unified Communications
Manager inserts the calling party’s directory number in the SIP contact header information. This is the
default setting.
• Deliver URI only in connected party, if available—In outgoing SIP messages, Cisco Unified
Communications Manager inserts the sending party’s directory URI in the SIP contact header. If a
directory URI is not available, Cisco Unified Communications Manager inserts the directory number
instead.
• Deliver URI and DN in connected party, if available—In outgoing SIP messages, Cisco Unified
Communications Manager inserts a blended address that includes the calling party's directory URI and
directory number in the SIP contact headers. If a directory URI is not available, Cisco Unified
Communications Manager includes the directory number only.
Step 4 Click Save.
Brandon
10-21-2016 09:37 AM
No, these calls are not traversing a SIP trunk.
After call processing CUCM sends these calls to the MGCP gatway.
Could these logs help to find out why the dialed number got the host name of CUCM?
60200581.001 |08:48:21.003 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setSipSPIMsgArg: deliverOriginalIdentityHeader=false; origNumber=, origName=
60200581.002 |08:48:21.003 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setPresentationIndication: namePi[0], numPi[0]
60200581.003 |08:48:21.003 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setScreeningIndication: si[1], oct3a[81]
60200581.004 |08:48:21.003 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setIdentityHeaders: ccb[e1a0b128], currLocalNum[+1123456789], currLocalNam[], callbackNumber[], localNumPi[0], localNamPi[0], id.flag[8], id.privacy[0], host[cucm-sub1.domainname.com], user[<NULL>]
60200581.005 |08:48:21.003 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setRpidHeader: rpidHdrStr[<sip:+1123456789@cucm-sub1.domainname.com>;party=calling;screen=yes;privacy=off]
60200581.006 |08:48:21.003 |AppInfo |//SIP/SIPHandler/ccbId=43227357/scbId=0/insertContactIntoContainer: USER=[+1123456789@]
60200581.007 |08:48:21.003 |AppInfo |//SIP/SIPHandler/ccbId=43227357/scbId=0/insertContactIntoContainer: Outgoing Contact=[<sip:+1123456789@10.10.10.2:5060;transport=tcp>]
60202292.001 |08:48:24.509 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/ccsip_call_util: $URI Blended Connected Party info in CONNECT msg: uri-+1123456789@cucm-sub1.domainname.com, dn-+1123456789, ti-DN
60202292.002 |08:48:24.509 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setSipSPIMsgArg: deliverOriginalIdentityHeader=false; origNumber=, origName=
60202292.003 |08:48:24.509 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setPresentationIndication: namePi[0], numPi[0]
60202292.004 |08:48:24.509 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setScreeningIndication: si[1], oct3a[81]
60202292.005 |08:48:24.509 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setIdentityHeaders: ccb[e1a0b128], currLocalNum[+1123456789], currLocalNam[], callbackNumber[], localNumPi[0], localNamPi[0], id.flag[8], id.privacy[0], host[cucm-sub1.domainname.com], user[<NULL>]
60202292.006 |08:48:24.509 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setRpidHeader: rpidHdrStr[<sip:+1123456789@cucm-sub1.domainname.com>;party=called;screen=yes;privacy=off]
60202292.007 |08:48:24.509 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/setRpidHeader: cached RPID hdr val <sip:+1123456789@10.10.10.2;user=phone>;party=x-cisco-original-called;privacy=off
60202293.001 |08:48:24.509 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 10.10.19.110 on port 50125 index 290089
[129992562,NET]
SIP/2.0 200 OK
Via: SIP/2.0/TCP 10.10.19.110:50125;branch=z9hG4bK6bb043d5
From: "Test user" <sip:+164088899@cucm-sub1.domainname.com>;tag=b07d47d3baea001835a37d2c-71726d4e
To: <sip:+1123456789@cucm-sub1.domainname.com>;tag=43227357~2c7a54c7-0d9e-4eff-84e0-78946b228486-44471474
Date: Fri, 21 Oct 2016 07:48:13 GMT
Call-ID: b07d47d3-baea0006-731d464b-49bda870@10.10.19.110
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Allow-Events: presence
Supported: replaces
Call-Info: <urn:x-cisco-remotecc:callinfo>; security= NotAuthenticated; orientation= to; gci= 1-638176; isVoip; call-instance= 1
Send-Info: conference, x-cisco-conference
Remote-Party-ID: <sip:+1123456789@cucm-sub1.domainname.com>;party=called;screen=yes;privacy=off
Session-ID: 93a59504db202a96ff7820bd44471475;remote=25451a7600105000a000b07d47d3baea
Remote-Party-ID: <sip:+1123456789@10.10.10.2;user=phone>;party=x-cisco-original-called;privacy=off
Contact: <sip:+1123456789@10.10.10.2:5060;transport=tcp>
Content-Type: application/sdp
Content-Length: 181
v=0
o=CiscoSystemsCCM-SIP 43227357 1 IN IP4 10.10.10.2
Calling party: +164088899
Called party:+1123456789
10-21-2016 11:50 AM
Check this service parameter - System > Service Parameters > Cisco CallManager > URI Dialing Display Preference. Is it set to URI or DN?
Brandon
10-23-2016 10:59 PM
It is set to DN.
11-24-2016 01:39 PM
Hello Ali,
did you solve your issue? We got the same with two installations upgraded one from 8.6 and one from 7.1 to 11.5.
Christian
11-28-2016 05:18 AM
Hi Christian,
11-28-2016 10:26 AM
Hi Ali/Christian,
I believe it's related to this bug and the fix that Ali nicely noted (+5 Ali!)
11-29-2016 01:37 AM
Thanks for your replies. My issue with the hostname portion when dialing was gone with setting the service parameter to false.
But i have in addition one more issue with 9971 phone and call list. No not an issue. When a user dialing to 9971, in the call list, the directory uri appears and not the number of the calling user.
When i delete the directory uri from the calling user, the phone shows the number. Is there any way to tell 9971 that it should display the number instead of the directory uri?
11-29-2016 02:16 AM
Hi Christian,
I've not faced the issue with 9971 but following articles may help you:
Originally Called Party Name in Placed CallHistory
Uniform Resource Identifier Dialing
The phone screen displays the call information for the URI call. The phone stores the URI call information in the Call History and the Details page. When you receive a call with a URI address, the URI address is stored in your Call History. Press Redial to call the most recently dialed URI address.
Depending upon how the administrator configures your phone, you may see either the URI or the Directory Number (DN) displayed for the incoming call alerts, call sessions and call history. If the phone is set to display the DN but only the URI is available, then the URI displays. If the phone is set to display the URI and only the DN is available, then the DN displays.
