07-08-2020 08:36 AM
Hello All,
CUCM & Unity Connection: v10.5(2)
The issue appears to only be with one person at the moment. If I call the user's extension from my extension it works just fine. But, if I call our System Call Handler from an outside line, like my cell, and then dial their extension when the greeting starts, I get sent straight to their voicemail.
Comparing a working extension/phone to this user's phone, everything appears to be the same for Partitions and CSS. If I call from the outside line and enter my extension, my phone rings. Also, the user doesn't currently have CFwdAll configured, so I know that's not it.
Running a CDR report filtering on my cell phone number, I can see I hit the CTI Route Point for the System Call Handler. Then, when I'm transferred to this user's extension, it appears to get translated to "8". I see no Translation Patterns in CUCM that would do this, and the Dialed Number Analyzer confirms this. CDR shows the "FinalCalledPartyNumber" as "8"... Very Strange.
Any ideas where I could look to see if there's something in place that is translating his Extension to "8" from his 2162 DN?
Thanks in Advance,
Matt
Solved! Go to Solution.
07-08-2020 08:40 AM
What do you have under the transfer settings for that user?
07-08-2020 08:40 AM
07-08-2020 09:50 AM
