External caller has no audio when we make outbound calls
belfairsacademy
Hi All
Complete rookie with this level of VOIP work but hope you might be able to break it down for what I need to be looking at.
All of a sudden we are having one way audio when we make external calls, we can here the external caller but they cannot hear us.
Incoming calls are fine and internal calls are also fine. Nothing has been changed on the system, other than a holiday schedule going live. I have tried removing this just to see if there was something underlying to cause this but has no luck.
We are running quite an old system, Cisco 7828 with a VG2921 gateway. CUCM version 8.5, ISDN30, have had the telco in and all lines report no issue. Never had any issues the system and support was left to expire before my appointment and then we struggled to be able to get any third party to support due to the age.
Any help on where to start looking would be amazing
8 Replies 8
Rajan
If possible you can get a packet capture from Phone used to make a call to have a look at the RTP streams.
Rajan
Pls rate all useful posts
Hi Rajan
Thanks for your reply, best way to go about getting a packet capture on the phone?
Hi Rajan,
Which protocol are you using between CUCM and VG?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo
what do you mean by which protocol?
Specific protocol will be used for communication between CUCM and Voice Gateway. You could check on CUCM whether the gateway is configured with MGCP or SIP.
Hi Rajan
The send and receive packets from the phone are reporting as 1800 each when i place a call and look at the stream stats on the actual phone.
Does this provide any useful info?
