04-15-2010 11:21 AM - edited 03-15-2019 10:18 PM
Hello again everybody,
Ever since I rolled out my fresh installation of CUCM 7.0(2)-22903, my phones ring differently when they receive calls from the PSTN. No matter the ringtone, the phone will ring twice back-to-back, then pause like normal, then rings twice again back-to-back. Does somebody have an idea what setting I need to check to remove this 'feature'?
Thanks again!
Justin
Solved! Go to Solution.
04-15-2010 11:30 AM
Hi Justin,
You are seeing/hearing this behaviour
*Distinctive ring for on- and off-net status this is a "distinctive cadence" based on the gateway setting. It is enabled by default. On the gateway configuration page you set the gateway as On-net or Off-net.
Cheers!
Rob
Please support CSC Helps Haiti
04-15-2010 11:30 AM
Hi Justin,
Cheers!
Rob
04-15-2010 12:05 PM
That seemed to have done the trick! Thanks for the help!
- Justin
