External number in Line Group Callmanager 8.6
am4_2_mau
Hi guys,
I need add one external number to receive calls to a line group.
Is this possible?
Jitender Bhandari
1. Create 1 dummy DNs on CallManager (dont associated with any phone)
2. Assign the dummy DNs as hunt group members for the required Hunt Pilot number
3. Create Remote Destination Profiles (RDP), with dummy DN pointing to the cell phone you want the call to be extended
As forwarding setting for Line group is ignored.
JB
7 Replies 7
Jitender Bhandari
JB
Thank you JB,
Your suggestion works.
Happy to help.
JB
Hi Jitender Bhandari,
Good day.
I'm trying your suggestion but not worked. Instead of mobile number, I added our skype for business number. I think I'm lost in creating RDP. Can you share what to config in RDP? Thanks!
Jayson
The feature is called Single Number Reach. This document may not match your version of CUCM, but the steps are pretty much the same for all recent versions:
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/200447-Single-Number-Reach-Feature-for-Cisco-Un.html
Hi Maren Honey,
Thank you very much for your help. I reviewed my configuration carefully,
added RDP and associate it with RD pointing to my designated skype number.
It worked!
Thanks to this forum specially to JB! Cheers!
Jayson
Glad I could help.
Don't call anyone honey on these forums.
