FA Codes are dislpayed in clear text
amit.bdkr
Hi All,
I am using CUCM 7.1.5.3 with SIP 9971 IP Phones when user enters forced authorization code on 9971 series phones it displayed in clear text insted of **.
so i need to upgrade phone load for that? or need to configure Phone with SCCP?
Thank You!!
Rob Huffman
Hi Amit,
This is due to a couple of Bug/Defects
CSCta93018            Bug Details
FAC is showing in clear text
Symptom:
While making a call outside through PSTN or Trunk and FAC is compulsary for that Route pattern and User provided the correct FAC. It is showing in clear text.
Conditions:
Workaround:
Further Problem Description:
StatusStatus
Open
Severity Severity
6 - enhancement
Last Modified Last Modified
In Last Year
Product Product
Cisco Unified IP Phones 9900 Series
Technology Technology
1st Found-In 1st Found-in
9.0(0)
CSCsb68946            Bug Details
SIP phone needs to replace digits with "*" in FAC
Symptom:
Currently, TNP phones (tested on 7970) will not block out the digits dialed for a FAC code.
Conditions:
Dialing a translation pattern with "Forced Authorization Code" from the phone will result in code digits being display on the phone while typed.
Workaround:
None.
StatusStatus
Open
Severity Severity
6 - enhancement
In Last Year
Product Product
Cisco Unified IP Phone 7900 Series
8.0(0.8)
Cheers!
Rob
