12-06-2014 12:08 PM - edited 03-17-2019 01:14 AM
Hello ,
I need a help in configuring FAC for international calls in CME 9.1, I m following the below link but i am confused for the configuration text highlighted below.
voice lpcor enable
voice lpcor custom
group 11 LocalUser
group 12 AnalogPhone
voice lpcor policy LocalUser
service fac
accept LocalUser fac
accept AnalogPhone fac
voice lpcor policy AnalogPhone
service fac
application
package auth
param passwd-prompt flash:en_bacd_welcome.au -----from where i will get this files ??
param passwd 54321
param user-prompt flash:en_bacd_enter_dest.au-----from where i will get this files ???
param term-digit #
param abort-digit *
param max-digits 32
thanks
12-06-2014 12:58 PM
the FAC in CME is a bit tricky.
FAC call flow in CME like follow
1) IP Phone user dials a particular pattern (international destination, for example)
2) If this destination is enabled for FAC, the user will hear a voice prompt asking for an Account number and PIN
3) The user enters the Account/PIN pair. If valid, the call proceeds, if not the call is dropped.
- If the authentication fails after three retries, the call drops without notification.
Configuration Steps:
1- upload "enter_account.au" and "enter_pin.au" to the flash files. you can record these files.
2- Enter the following commands in configuration mode (in this example the Account and PIN are three digits long). This forces a user id and pid length, but it not required:
application
service clid_authen_collect
param uid-len 3 *length id 3 characters (can be user ext)
param pin-len 3 *length pin 3 characters
3- Create usernames for authentication. Notice that the username/password will represent the Account and PIN that the caller will have to dial to be successfully authenticated. You can create multiple usernames and then hand those out to select personnel that will be allowed to place premium calls. In this example both Account and PIN are three digits long.
12-06-2014 01:47 PM
thanks for the reply Anas,
Point 5,6 i didnt understood can you elaborate more.
i have recorded the file and tried to convert in .au format and successfully converted.
i want to apply on only international calls as dial-peer shown below so what will be the lpcor ??
dial-peer voice 2 pots
corlist outgoing call-international
description International calling
destination-pattern 9T
direct-inward-dial
port 0/0/0:15
12-06-2014 02:00 PM
the idea of point 5 and 6 simply like the below:
you have international dial-peer and you need to restrict the access to this dial-peer.
the call flow like the below
users dial international number ==> it matches FAC voip Dial-peer ==> prompt for authentication ==> successful authentication ==> it matches pots dial-peer and proceed.
to achieve that we use cor list
1- user digit has FAC incoming corlist divert you to FAC voip dialpeer
2- Successful authentication
3- FAC dialpeer corlist incoming divery the call to international pots dialpeer
Anas
don't forget to rate the helpful posts
12-07-2014 11:31 AM
12-07-2014 12:43 PM
kindly find the below config
application
param uid-len 3
param pin-len 3
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local and network authorization
aaa authorization network h323 local for h323
username 211 password 123
username 211 autocommand exit
voice lpcor custom
group 1 manager
group 2 users
voice lpcor policy manager
service fac
accept manager fac
accept users fac
dial-peer cor custom
name fac-int
name user-fac
dial-peer cor list fac-int
member fac-int
dial-peer cor list user-fac
member user-fac
dial-peer cor list user-international
member internal
member emergency
member toll-free
member user-fac
member national
dial-peer voice 20 voip
corlist incoming fac-int
corlist outgoing user-fac
session target ipv4:192.168.4.2
incoming called-number 9T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
corlist outgoing fac-int
direct-inward-dial
port 0/0/0:15
Anas
05-16-2016 07:03 AM
Thank you for the post. It has really helped me understand how FAC works. For me, I want to restrict users from making external calls unless they put the unique code given to them. My main aim is to be able to give accurate billing statements. However, I'm not sure about the Manager group being created. I assume any user whose not authorized to input a user and pass will not be prompted? Please take a look at my configs and advice
voice ipcor custom
group 1 users
voice ipcor policy manager
service fac
accept users fac
name fac-incoming
name user-fac
dial-peer cor list fac-incoming
member fac-incoming
member user-fac
dial-peer voice 110 voip
*corlist incoming fac-incoming
*corlist outgoing user-fac
*service clid_authen_collect
description OUTBOUND CALLS via MPLS
translation-profile outgoing OUTGOING_CALLS
redirect ip2ip
session protocol sipv2
session target ipv4:10.66.56.138
voice-class codec 2
dtmf-relay rtp-nte
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
Thanks.
