FAC LPCOR IS NOT WORKING IN CME SIP PHONES
lajan jaleel
Dear Team,
We are planning to put FAC on SIP (7821) phones for calling long distance.
CME version is 10.0
Please find the config
gw-accounting aaa
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
aaa session-id common
voice register global
 mode  cme
 source-address 10.X.X.X port 5060
 timeouts interdigit 5
 max-dn 500
 max-pool 475
 load 7821 sip78xx.10-2-1-12
 authenticate register
 authenticate realm router.local
 timezone 35
 tftp-path flash:
 create profile sync 0003478159444525
voice lpcor enable
voice lpcor custom
 group 1 national-FAC
voice lpcor policy national-FAC
 service fac
 accept national-FAC fac
application
 package auth
  param max-retries 0
  param passwd-prompt flash0:/enter_pin.au
  param abort-digit *
  param user-prompt flash0:/enter_account.au
  param passwd 12345
  param term-digit #
  param max-digits 32
username 1111 password 7 1446435A5D
voice register pool  2
 lpcor type local
 lpcor incoming national-FAC
 lpcor outgoing national-FAC
 busy-trigger-per-button 1
 id mac F09E.636F.0F4B
 type 7821
 number 1 dn 2
 template 1
 cor incoming NATIONALACCESS 1 3002
 dtmf-relay rtp-nte sip-notify
 username user2 password cisco
 codec g711ulaw
voice register dn  2
 number 3002
 call-forward b2bua noan 5000 timeout 20
 allow watch
 name 3002
 label 3002
dial-peer voice 117 voip
 destination-pattern 905[0256].......$
 session protocol sipv2
 session target ipv4:10.X.X.X
 incoming called-number .
 codec g711ulaw
 no vad
 label 3004
CME#dir flash:
Directory of flash0:/
    1  -rw-    96910452  Oct 21 2014 03:35:18 +04:00  c3900e-universalk9-mz.SPA.153-3.M3.bin
    2  -rw-        3064  Oct 21 2014 03:49:06 +04:00  cpconfig-39xx.cfg
    3  drw-           0  Nov 12 2014 14:09:54 +04:00  its
   14  drw-           0  Nov 12 2014 15:16:46 +04:00  GUI
   32  drw-           0  Oct 21 2014 03:49:32 +04:00  ccpexp
  273  -rw-        2464  Oct 21 2014 03:51:18 +04:00  home.shtml
  274  -rw-      116608  Nov 12 2014 15:10:32 +04:00  CME-GUI.rar
  275  -rw-     3090800  Nov 12 2014 16:35:04 +04:00  kern78xx.10-2-1-12.sbn
  276  -rw-    36307280  Nov 12 2014 16:36:00 +04:00  rootfs78xx.10-2-1-12.sbn
  277  -rw-      364072  Nov 12 2014 16:36:10 +04:00  sboot78xx.10-2-1-12.sbn
  278  -rw-        1228  Nov 12 2014 16:36:32 +04:00  sip78xx.10-2-1-12.loads
  279  -rw-      496521  Nov 12 2014 17:01:40 +04:00  music-on-hold.au
  280  -rw-       23660  Nov 19 2014 14:48:40 +04:00  enter_account.au
  281  -rw-       24164  Nov 19 2014 14:48:48 +04:00  enter_pin.au
261324800 bytes total (120594432 bytes free)
But when ever iam trying mobile calls call is disconnecting. please find the debugs
Nov 19 20:04:34.661: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_peer:
   peer tag 40001, direction 0
Nov 19 20:04:34.661: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
   lpcor International-FAC
   lpcor International-FAC index 1
   Return Lpcor Index 1 for Peer Tag 40001
DAMAC_AKOYA-CME#
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_index_is_valid:
   lpcor index 1 is valid
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_policy_validate_internal:
   Source LPCOR Index=1, Target LPCOR Policy=International-FAC
Nov 19 20:04:39.225: -Traceback= 19E34D6z 581A4DCz 581AC7Fz 55B3588z 55B3063z 55AEA34z 55B6A53z 55B7255z 55B649Bz 55F5AF5z 5583EEFz 55894B6z 5589734z 55F5AF5z 558A44Az 55CF04Ez
DAMAC_AKOYA-CME#
   Validate Pass; lpcor (source[1] target[1])
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_policy_validate_get_service:
   FAC is enabled; lpcor (source[1] target[1])
Please advise. If iam missing any steps in this.
LAJAN JALEEL
5 Replies 5
Amit Kumar
Hello Lajan,
I guess, the  LPCOR policy applied in dial-peer, do not exists in configuration:
 codec g711ulaw
 no vad
As per configuration snip pasted above, and what applied in voice register pool it should be, International-FAC
 lpcor type local
 lpcor incoming International-FAC
 lpcor outgoing International-FAC
It should work, after updating correct policy on dial-peer.
Amit
Dear Amit,
Thanks for your reply.
That was a mistake while pasting the config.
 lpcor type local
 type 7821
|This is the real config. this config is not working.
Kindly advise.
Hi ,
It should be lpcor incoming , tag should be exactly same what you have configured while defining LPCOR policy:
if this is real config for lpcor policy:
voice lpcor policy International-FAC
 service fac
then both dial-peer and voice register pool should be having same TAG, which is " International-FAC"
if that's same and still its failing, then please collect below said debug in addition to what you have collected already:
debug voip application auth
Amit
Dear Amit,
Will try the same and update.
So that means iam not missing any steps right? What ever i was doing is right only some things needs to be changed right?
Dear Amit,
The configuration is working fine. We find out what is the exact issue.
*****Issue******
Debug voice application auth was giving an out put that
user prompt url is not found , Even though the exact directory was there under flash0:
CME#dir flash:
my application configuration was like this:
application
package auth
  param max-retries 0
  param term-digit #
  param abort-digit *
  param passwd 12345
  param max-digits 32
*****Resolution*****
changed user prompt and password prompt from flash0:/ to flash:/
application
package auth
  param passwd-prompt flash:/enter_pin.au
  param max-retries 0
  param term-digit #
  param user-prompt flash:/enter_account.au
  param abort-digit *
  param passwd 12345
  param max-digits 32
Right now lpcor is working fine for Long Distance calls with the same config.
Thanks All
