Factory Reset 7970
silvakizir
Hi guys.
I have a working 7970 phone.
I did a Hard Factory Reset with 3491672850*# and now following the instructions from this site: http://www.allthingscisco.com/factory-reset-cisco-7940-7960-7941-7961-ip-phones/    I can't make the phone work.
I've tried with the tftpd32 directly to the phone, I've tried a CME with the phone, I've tried CUCM with the phone but nothing happens.
I've tried various firmware starting from 8.3.2 which is the first one.
The only messages I can see in tftpd are the bellow.
Connection received from 10.0.0.13 on port 51237 [06/03 08:51:03.078]
Read request for file <term75.default.loads>. Mode octet [06/03 08:51:03.078]
Using local port 52468 [06/03 08:51:03.078]
<term75.default.loads>: sent 2 blks, 642 bytes in 0 s. 0 blk resent [06/03 08:51:03.078]
Connection received from 10.0.0.13 on port 50794 [06/03 08:51:38.080]
Read request for file <term75.default.loads>. Mode octet [06/03 08:51:38.080]
Using local port 52471 [06/03 08:51:38.080]
<term75.default.loads>: sent 2 blks, 642 bytes in 0 s. 0 blk resent [06/03 08:51:38.080]
Phone takes an IP, then I see the messages, then it reloads and every 5 minute the same thing.
Can anyone help me?.
So Is the issue resolved now?
5 Replies 5
Mikolaj Moryto
I believe the file phone is trying to download doesn't exist in C:\Program Files\Tftpd64 directory. You need to change the directory or make sure file exists in the current one.
Mikolaj
Yes my friend you are right. Unfortunately I've put wrong image and I just deleted it.
The actual Logs are the bellow.
I accidentally marked your answer as correct. How can I undo this.
I figured how to solve my problem and I had to put the latest firmware in order to make it work. Everyone said to put the lowest firmware after Hard Factory Reseting a phone but the only firmware that worked was the last one.
Thank you
Not sure if can undo it. Try marking it as unanswered.
Haris
