04-16-2013 12:36 PM - edited 03-16-2019 04:50 PM
Dears,
sometime in a day when i dial to pstn it gives me fast busy tone then again when i dial again it gives me fast busy tone i have to wait for 15 to 20 sec and when i try it works fine but this happen intermitent, and also sometime the call are dropping while speaking
How i have to troubleshoot for these two type of problem, fast busy tone and call dropped.
04-16-2013 12:58 PM
what is your voice gateway, H323 or MGCP ? what is your PSTN connection , FXO or E1 ?
regards
Anas
04-16-2013 11:59 PM
The voice gateway is H323 and it is a E1 controller
04-17-2013 12:40 AM
Hi Clark.
I would check with the provider the status of E1 circuit and the connectivity between CUCM and VG.
This also occurs when no E1 channel is available.
Please activate a debug isdn q931 and see what happens when you receive a fast buy tone.
Carlo
Please rate all helpful post.
04-25-2013 01:00 AM
Hello ,
I am receiving the below logs in the router logging, may be because of this my call are dropped, I am not using any IVR system
%IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (96/100).
Call (callID=1521092) is rejected.
My IOS version is c2951-universalk9-mz.SPA.150-1.M6.bin
04-25-2013 02:58 AM
Hello
please clark us the below link which have the same issue
https://supportforums.cisco.com/thread/2144918
please also share sh processes cpu history
thank you
please rate if this will help
04-25-2013 02:25 AM
Hi Clark.
Please post your vg conf.
Thx
Carlo
04-25-2013 02:57 AM
Hello
please find the attached
sorry i have removed uploaded for the timebeing only.
04-25-2013 03:21 AM
Hi Clark,
In addition to what Mr. Kamal has asked , I wouldsuggest to upgrade the image to c2951-universalk9-mz.SPA.150-1.M10.bin which is the latest available since 15.0 M is the maintenance release.
regds,
aman
04-25-2013 03:32 AM
Hello Clark
I agreed with Mr/amanso , try to do that and please share also command which i asked above .Thanks for mr/amanso for his quick answers everytime.
Thank you
04-25-2013 03:39 AM
04-25-2013 04:11 AM
Hello
can you share also the below commands
show proc cpu sorted
show process cpu
please do a call which cause the same error then do the above commands .
Thank you
04-30-2013 04:44 AM
Here are the below logs,AFW application rises unexpectedly i have upgrade the IOS universalk9-mz.SPA.150-1.M10.bin, should i change a train from 15.0 to 15.3
CPU utilization for five seconds: 98%/8%; one minute: 97%; five minutes: 58%
PID Runtime(uS) Invoked uSecs 5Sec 1Min 5Min TTY Process
285 1593408000 1157748 1376 49.91% 50.67% 30.76% 0 CCH323_CT
122 412276000 1304031 316 14.79% 14.68% 8.80% 0 IP Input
157 36928000 559448 66 3.67% 4.48% 2.68% 0 TCP Timer
307 2364000 31661 74 3.11% 1.17% 0.51% 0 AFW_application_
274 28932000 99613 290 2.71% 2.81% 1.51% 0 VOIP_RTCP
187 3368000 46576 72 2.15% 1.19% 0.65% 0 AFW_application_
308 2076000 31530 65 2.07% 1.05% 0.48% 0 AFW_application_
312 1092000 14447 75 1.75% 0.87% 0.27% 0 AFW_application_
309 2020000 28441 71 1.75% 1.03% 0.45% 0 AFW_application_
311 1668000 20219 82 1.67% 1.00% 0.37% 0 AFW_application_
310 1984000 27116 73 1.67% 1.03% 0.44% 0 AFW_application_
%IVR-3-LOW_CPU_RESOURCE: IVR: System experiencing high cpu utilization (97/100).
Call (callID=46357) is rejected.
sh logging.
Call (callID=) is rejected.
04-30-2013 04:54 AM
Hi Clark,
Application Framework error which is coming is related to TCL scripts.Canu post your config along with version ?
regds,
aman
04-30-2013 05:00 AM
