FAX issue with FXS port CME 7.1
I have a problem for receiving fax wich is connected to FXS port. I can make and received call but for fax something happen, the fax´s
display shows receiving and then stop, the calling received a busy message; also the port remains some seconds seized even though the call finished.
I have reviewied many post about FXS for fax but many differences between them.
My config  is the next
network-clock-participate wic 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
modem passthrough nse codec g711ulaw
controller E1 0/0/0
framing NO-CRC4
ds0-group 1 timeslots 1-15 type r2-digital r2-compelled ani
cas-custom 1
  country telmex
  category 2
  answer-signal group-b 1
  caller-digits 4
voice-port 0/2/1
cptone MX
description FXS FAX 1190
dial-peer voice 112 pots
description FAX 1190
destination-pattern 1190
port 0/2/1
ROuter 2921, CME 7.1 , FXS card VIC3-2FXS/DID
c2900-universalk9-mz.SPA.150-1.M2.bin
there is something left , or should I change something??
regards
15 Replies 15
Hi Filiberto,
From your attached configuration file, I found out you didn't configure voice port in your dial-peer
destination-pattern 1190  --------------->faX NUMBER
If follow your description in your configuration you should configure a voice port in this dial-peer as below:
port 0/2/1
