Fax OnRamp Issue
nreyesvgkn
I did the following configuration:
hostname Router
ip domain name infomicro.local
ip name-server 192.168.0.100
fax receive called-subscriber $d$
fax interface-type fax-mail
mta send server 192.168.0.100 port 25
mta send subject "Cisco FAX to Mail"
mta send postmaster nelson@infomicro.local
mta send mail-from hostname Router.infomicro.local
mta send mail-from username $s$
application
service fax-onramp flash:app_faxmail_onramp.2.0.1.3.tcl
interface GigabitEthernet0/1
ip address 192.168.10.130 255.255.255.0
duplex auto
speed auto
dial-peer voice 40 pots
service fax-onramp
incoming called-number 5551234
direct-inward-dial
dial-peer voice 41 mmoip
service fax_on_vfc_onramp_app out-bound
max-conn 5
destination-pattern 5551234
information-type fax
session target mailto:fax@infomicro.local
When I make a call to the 5551234 the call begin the ring and after 2 or 3 seconds the call is answered, but that is all, the fxo port where I'm connecting the incoming line bring up and immediatly close the channel, I mean, disconect the call.
My question is, what is wrong? what I'm forgetting?
Hope somebody can help me
Nelson
PS: sorry about my english
STEFAN CHRISTEN
Level 5
Level 5
Hi Nelson
I haven't checked all your config but you're missing a POTS dialpeer to the FXO port. The FXO voice port should also have the "signal did" command because DID is not enabled by default (as far as I know).
http://www.cisco.com/en/US/docs/ios/voice/isdn/configuration/guide/vi_ext_mod_vcfx_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1027195
Stefan
I'm using a Cisco 3825 with Cisco Internetwork Operating System. Cisco IOS (tm) C3825 C3825-ADVIPSERVICESK9-M, The System version is 12.4(15)T7 / CME 4.1(0) and I try to configure a "T.37 Store and Forward Fax" but when I download the latest version of tcl script (app-faxmail-onramp.2.0.1.3.zip and app-faxmail-offramp.2.0.1.1.zip) and I put it on my router cannot do anything!!!.
And when I check how to solve this problem I found when I put in the CLI the command: "sh call application voice onramp_kywi" (onramp_kywi calls the script app-faxmail-onramp.2.0.1.3.zip) only have the next response:
Script Name : onramp_kywi
URL : flash:app-faxmail-onramp.2.0.1.2.tcl
Type : Service
State: Not Loaded
Life : Configured
Exec Instances: 0
Script Code Begin:
The same thing ocurs with the offramp script.
The most "worrying" part is when the command says about the script "State: Not Loaded"
Do you have any fix/solution to this problem???...I need urgent help.
Thanks!!
You need to reload the router to load the script.
