fax tone answers and then stops
iptuser55
Level 6
Level 6
We have a fax server which is working however the fax tone after we cut acrosss from TDM to IPT is short. You hear the tone for a few seconds and then it stops as if it is suppressed. Is there a debug we can run to confirm this or provide answer to the fax guys why this is correct and is working as designed - thanks
ivillegas
Level 6
Level 6
Enable the following debugs.
undebug all
debug isdn q931
debug voip ccapi inout
debug voip vtsp all
debug voip ivr script
debug voip application script
debug fax relay t30 all
debug voip application tclcommands
