11-05-2008
07:37 AM
- last edited on
03-25-2019
07:45 PM
by
ciscomoderator
How does the DND feature work on CME? Does it simply silence the phone and let the CFNA timer expire and then foward to CFNA destination or should it bypass the CFNA timer and send the call to the CFNA destination immediately?
Solved! Go to Solution.
11-05-2008 08:32 AM
It simply silences the ringer and lets the timer expire. If you want the call to go to VM immidatelly then you would engage callForwardAll and press Messages button.
HTH,
Chris
11-05-2008 08:32 AM
HTH,
Chris
