Faxes Failing over SIP
jim.stengle
We have a SIP trunk from a provider coming into a 4331 CUBE. It goes SIP to CUCM. Then we have VG204s off CUCM via SCCP. There is a fax machine on the VG204. All faxes fail. The disconnect cause is 16 - Normal. However the fax reports an error in transmission. Originally we had the CUBE set for T.38 version 3. I have backed it down to T.38 version since the client advised they only require G3. Still does not work. Here is the CUBE config:
voice service voip
mode border-element
allow-connections sip to sip
redirect ip2ip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
header-passing
error-passthru
registrar server expires max 600 min 60
asserted-id pai
no update-callerid
midcall-signaling passthru
privacy-policy passthru
g729 annexb-all
no call service stop
We are requiring MTP resources on all calls for the trunk so I have MTP resources registered off the CUBE.
Any thoughts as to what could be wrong?
Chris Deren
SCCP does not support protocol based T38 which is what you show configured, you need to either convert the SCCP ports to SIP/MGCP/H323 or check with provider if G711 passthrough can be used.
